Will a 93 kx250 front wheel...
Posted: 07:22 am Apr 25 2005
by layoutd
fit 1996 forks? what years match up on the 1996s
Posted: 07:27 am Apr 25 2005
by Indawoods
'96 to '02 fits a 96 KX frontend. a '93 will not.
Posted: 10:37 am Apr 25 2005
According to my sources, the '93 - '98 front hub is the same part number. You may want to check
http://www.buykawasaki.com to check on the parts numbers.
Posted: 11:00 am Apr 25 2005
by Indawoods
OK then...there you go!
Posted: 11:17 am Apr 25 2005
I didn't say it would fit.
I just said the hub is the same.
You can check front brake pad year model fit and other stuff to help see if it may fit. Most of the axle parts were for '93 - '98 also. Checking buykawasaki.com is the way to go, usually. Just open one window with one bike and open another window with the other bike and start trying to match.
