Measuring Fork Oil
Posted: 08:04 am Oct 12 2008
by KDX Butterfly
Is there a "simple standard" for measuring fork oil. Yes, I admit, I have procrastinated on putting the oil in just for the simple fact that I am not real sure of how to measure the oil. Just keep in mind that I DID clean, change the fork seals, and replace the forks with next to no help. I'm learning.
Thanks everyone!
Posted: 08:25 am Oct 12 2008
by Indawoods
Mike knows... he just did it in his!
Posted: 11:34 am Oct 12 2008
by KDX Butterfly
Just seeking other suggestions, Vince.
Posted: 11:42 am Oct 12 2008
by Indawoods
OK then...
Posted: 05:56 pm Oct 12 2008
by KDX Butterfly
mind your own business ...
Posted: 09:17 pm Oct 12 2008
by Colorado Mike
wow, tough room. Sounds like somebody could use the hot bubble bath-fumey candles-dove bar- and girly music treatment.
anyway..
I just use a horse syringe hooked to a piece of aquarium tube hooked to a piece of brass fuel line. I drilled a snug fitting hole in a hunk of wood to slide the fuel line through, so I can adjust the oil level.
Posted: 11:15 pm Oct 12 2008
by SVandal
There is cool little tool like what is described above, measure the length of brass tubing to determine how far down it is before it can't reach any more fluid.
Posted: 05:51 am Oct 13 2008
by KDX Butterfly
Colorado Mike wrote:wow, tough room. Sounds like somebody could use the hot bubble bath-fumey candles-dove bar- and girly music treatment.
No bubbly bath, maybe
A fumey candle, no dove bar, and if you consider Pantera girly music, well then ok.
Thanks for the suggestions Colorado Mike and SVandal. Anyone else? Maybe I can create (ha) my own "blonde-girly" concoction.
Posted: 10:29 am Oct 13 2008
by Colorado Mike
All the good girls are already taken.
Posted: 12:28 pm Oct 13 2008
by jc7622
Posted: 01:31 pm Oct 13 2008
by Indawoods
I have what you need.... I will make up a fork level gauge for ya and bring it over Saturday..... Cool?
Ever find your manual?
Posted: 04:21 pm Oct 13 2008
by canyncarvr
As has been said..a large animal syringe from your local Fleet store, some tubing, you're done.
Don't fret over the tubing being exactly straight...or not. So..you measure from where the syringe will rest on the fork tube to the end of the tubing, cut it at the 110mm length. Ahhh...but the tubing is
bent a little bit, so is it going to be 108mm??
You won't know the difference most likely.
I've measured the oil level after using a bit of curled tubing..when I considered it might matter. The level was a bit high..so cut some a couple mm longer than the desired end result!
If the cut isn't parallel to the oil surface you're going to get an 'erroneous' reading anyway.
Short answer: Doan worry 'bout it. If you can tell the difference between 110mm and 108mm in your fork oil level when you ride the bike...you probably should be riding an $8000 punkin and pay some exspurt to work on it for 'ya.
....what's that bath-fumey-kind'a candle smell??
Posted: 07:25 pm Oct 13 2008
by KDX Butterfly
canyncarvr wrote:....what's that bath-fumey-kind'a candle smell??
I do beleave it has to do with either my ol' man's sulfer residew from the match he lit in the bathrum shortly after he left the door open....
Otherwise.... use yer magin-a-tion ... aaaahhhh ... mmmm
Like Colorado Mike said ... "All the good girls are taken..." I'm not good but I'm not totally bad either. (Workin' on it though ... ha)
Bath, fumey kinda stuff? Whatz that?
Posted: 08:36 pm Oct 13 2008
by Colorado Mike
This all stems from my mis-assumption about the required maintenance level of wimmens in general. I should have known one that had the presence of mind to be from the Durango, CO. area would be much above average in her ability to take enjoyment from the joys in life that matter most.
Regrettably, my only defense is that I was raised wrong, by wolves, and with little female influence.
Posted: 09:29 pm Oct 13 2008
by scheckaet
sumthin like dat?
Posted: 10:19 pm Oct 13 2008
by Mr. Wibbens
Hmmmm, I used a syringe but without the tubing
I put a hose clamp on the syringe, to act as a stop, at my chosen depth
Posted: 05:37 am Oct 14 2008
by KDX Butterfly
I will save the picture.
Colorado Mike ... Not a darn thing wrong with bein' raised by wolves. Be proud.
K, Inda.
