There's a ships-passing-in-the-night thing going on here, folks..
Question: Does the piston come with pin and bearing?
Answers: Order separate and 'piston+bearing' separate.
..which leaves out exactly what of everything you need is or isn't in the 'kit'. Well..as I understand what I read anyway. I don't understand too good sometimes. I don't get the 'implied' parts of missing facts a good lot of the time.
The Pro-X piston (from MaKaw) will come with a pin..and with clips, but not the bearing, not rings. The Wiseco comes with rings, clips, and the pin..but not the bearing.
I have
NOT ordered such from RMMC myself.
The description of the Wiseco 'kit' says:
Piston kit includes piston, rings, wristpin and circlips.
I just looked up a KDX 200 'kit' Part# 1038400057. That is the description for that 'kit'. I asked via a 'chat' window:
I wrote:Re:Part# 1038400057, Wiseco 'kit'. I would like to verify that the description is correct..piston, rings, pin and clips...but NO bearing..right?
The chat window sayeth:
lori wrote:Right.
OkeyDokey?
Oh...Wiseco Piston Wristpin Bearing:
Fits: 2000, KAWASAKI, KDX200
Regular: $14.95
Our price: $11.99
Part# 1038430008
This item is In-Stock
I'd never re-use a pin or clips. I've never re-used a bearing..but I might be tempted next time I don't have one on-hand.
Certainly never use a Pro-X pin/clips with a Wiseco. I'm sure that's intuitvely obvious to the most casual observer.
This should be an old story..but make sure those clips
SNICK into place. Time was when Wiseco pins were a tad long...poorly/improperly seated clips came OUT..and that NOT at a good time!!
