I broke off one of 4 axle pinch studs on my kdx 220 (need to
Posted: 07:18 pm Jun 26 2008
by Motodeficient
I broke off one of 4 axle pinch studs on my kdx 220 (need to invest in a inch/lb torque wrench :banghead: ). It is the upper one closest to the hub.
2 Questions:
1. Are those studs that can be replaced? Or are the all one piece molded with the fork tube?
2. Is it safe to ride the bike with one of these missing? There is still one upper and two lower holding the axle pinch clamp there.
Thanks In Advance
Posted: 09:39 pm Jun 26 2008
by Rick
Should be ok to ride........
Posted: 11:30 am Jun 27 2008
by DeSoto Flyer
You are not alone! I broke one of the pinch bolts off as well. Yes, it can be fixed. Use some penetrating oil on the pinch bolt where it goes into the fork leg. Use a vise grip and unscrew the bolt. It comes out counterclockwise, just as you would expect. Do the same with one of the good bolts, so you can take it to a dealer (or hardware store) to try and match it. You will need the good one, since the broken one will not give you a correct size.
Kawasaki does not list a part number for the bolts, they would rather you buy an entire fork leg.
What I thought was a disaster turned out to be just a minor inconvenience.
We have a smart, experienced parts manager here, and he was able to find a barrel bolt that matched almost perfect - just a hair longer than stock. You could use a regular bolt, but they are not as strong as a barrel bolt. Of course, a regular bolt would be stronger than having nothing.
I can't get a photo uploaded on here, but pm me if you want a photo of the bolt.
Posted: 03:08 pm Jun 27 2008
by Dewey
I have used a long set screw from a bolt supply store to replace these before. Don't forget the loctite!
The problem with using a standard bolt is, you may run it in to deep and damage the threads in the bottom of the hole. Then when you remove the bolt the threads come with it.
By using a set screw you can loctite it and feel when it bottoms in the threads, let the loctite cure and then install clamps and nut. Plus you can hold it with an allen wrench when you remove the nut so the set screw stays in place.
Of course OEM stud would be better if you can find it!
Posted: 03:53 pm Jun 27 2008
by 2001kdx
It happens all the time - it's very rideable as is but the replacement can be picked up at your local hardware store.
Posted: 06:53 pm Jun 27 2008
by KDXSean
Go to your Kawi dealer and have them search this part # for the stud
172G0622
I found this somewhere, sometime, from someone. Don't remember where.
Give it a try, I've never checked it out cause I've never snapped one off.
You should invest in a in-lb torque wrench
Sean
Posted: 07:46 pm Jun 27 2008
by Motodeficient
Yeah I ordered a couple of those studs. THey are only 70 cents each. I will ride it like it is until they come in then replace the broken one. Thanks! I will definitely also be getting an inch/lb torque wrench.
Posted: 05:01 pm Jun 28 2008
by AZRickD
My local Kawi dealer tried to charge me $10.50 for that bolt and I'd have to wait 4-7 business days for it to be "shipped" in from the California "warehouse."
Ace Hardware, instead. Or you can pick up one of those "Japanese Dirt Bike bolt kits." for $11 at a fraction of the per-bolt price from "the warehouse."
Rick
Posted: 08:21 pm Jun 28 2008
by canyncarvr
AZRick: You DO know you got bent over, right?
I have one'a those studs in my tub-o-stuff (not of much use on USD forks)..and it cost less than a buck...from the local dealer.
Didn't look, but...what is it? Something like 18in/lb? Not much!!
Do insure your put it together so that there is NO gap at the top.
The gap is at the BOTTOM! So...snug the TOP nuts first.
Posted: 07:55 pm Jul 02 2008
by Motodeficient
Yeah actually the manuall says 87 inch/lb
Yes what I do is tighten the top nuts halfway, then compress the forks a few times to align them. then tighten everything up.
I ordered two of the studs from bike bandit. I think it came to $6 something including shipping
Posted: 04:44 pm Jul 09 2008
by canyncarvr
Yeah....87in/lb sounds good.
I should'a not said anything having not looked it up myself.
Thanks for posting the correct torque!
