Page 1 of 4
Gearbox Oil Poll
Posted: 10:41 pm May 23 2008
by rdsrf
I found the discussion on gearbox oil in the "horrible squealing screching noise" thread rather interesting. Especially the article in the link CC put in there. What's everyone out there using and what are your experiences?
Posted: 11:01 pm May 23 2008
by NM_KDX200
I've been using Rotella T in my KX.
I used ATF and whatever 10-30 I had on hand in my KDX200.
Maybe I'll switch to something else...
by canyncarvr
So...where's the poll part?
Vote
HERE! ...until Inda puts 'em together maybe?
FWIW I use Yamalube 10/30-40. I used to use 'motor oil'. Valvoline. For motorcycles even. It met spec. My clutch squealed like a stuck pig. I haven't heard a peep out of it since the switch...and I 'use' it quite a bit more now than I did then.
Similar situation in my Honda (700SC). When the tune of the bike hit (around 9KRPM or so), the clutch would slip. New friction plates, new steels, new springs...same. With Yamalube (and another set of new everything)..no slip no more.
Note the input on oil on the link mentioned came from a Maxima geru. Another FWIW I s'pose, but it was based on a tad more than what some rider thought about it.
Gearbox oil poll
Posted: 11:11 pm May 23 2008
by canyncarvr
Fits with rd's question
HERE!
Posted: 11:13 pm May 23 2008
by canyncarvr
Wow!! Right now....100% of the votes and voters say
YAMALUBE!!!
yippee!
Posted: 08:48 am May 24 2008
by skipro3
I don't see my choice and there's no "other" for a choice either. I run Rotella in a straight 30 wt oil. Rotella is made by Shell I think and is for diesel motors. Diesel engine oil is formulated to hold particles in suspension more than standard oils do. Anyone who owns a diesel knows that within 100 miles, the oil looks like it's been run 100,000 miles it turns soooo BLACK!!! It really has to hold a lot of crap so I figure it works well in our bikes that don't have motor oil filters. I don't want gunk settling out into the bottom or any where else for that matter.
Posted: 10:10 am May 24 2008
by skythrasher
I voted on the motorcycle specific line, but I use motorcycle specific Golden Spectro 10-40. No squeals no slips.
Posted: 10:39 am May 24 2008
by 2001kdx
ATF type F.
Posted: 12:24 pm May 24 2008
by rdsrf
I hadn't heard of ATF being used until recently. How does it perform for you? Good shift quality?
Posted: 12:47 pm May 24 2008
by 2001kdx
Awesome. I never used to be able to kick my bike over in gear with one kick, it took two, but now with the ATF it's first kick. Really helps on dead engine starts. $3.30 a quart and I change it every 5 hours.
Posted: 01:19 pm May 24 2008
by JoeR
GM Sythetic Gearbox Lube. I had a couple of quarts of it in the garage left over from a trans repair. Shifts nice, clutch works good, isn't burned up when I drain it....so I'll probably stick with it.
Joe
Posted: 08:37 pm May 24 2008
by blimpman
I use a 2-part ATF & 1 part 30W Quality Motor Oil mixture. Change it every three rides. Trans shifts smooth as butter...
Posted: 10:28 pm May 24 2008
by canyncarvr
**update* If 'your' choice isn't listed, it's 'cuz it wasn't worth the time to type it up.
the editor
**end update**
btw...where did THIS idea ever get hatched?
'I use a 2-part ATF & 1 part 30W Quality Motor Oil mixture.'
Posted: 11:29 pm May 24 2008
by 2001kdx
I've seen that alot from riders on ThumperTalk; maybe it's becuase they think ATF is too thin?
Posted: 05:38 am May 25 2008
by blimpman
canyncarvr wrote:**update* If 'your' choice isn't listed, it's 'cuz it wasn't worth the time to type it up.
the editor
**end update**
A guy named Ron....
by rick albert
i use ATF - due to my A- clutch !!!!!
Posted: 07:35 am May 25 2008
by Jeb
the editor
**end update**
A guy named Ron....
Yep, that's where I got it from, except quoting him it was "2 parts ATF..... 1 Part 10W/30 or 10W/40
GTX." And, yes, the GTX was in bold lime . . . for whatever reason!
Hatched righ'cheer on this website!
Posted: 09:18 am May 25 2008
by NM_KDX200
skipro3 wrote: I run Rotella in a straight 30 wt oil.
Same here. I ran it in my YZ450F and it seemed to do well (changing every 5 hours anyway), so I just ran it in the bottom end of my 125.
Posted: 10:46 am May 25 2008
by canyncarvr
Re: 'A guy named Ron....'
That is funny on SO many levels of humor...you have NO idea.
Anyway, thanks for the info.
Posted: 08:12 pm May 25 2008
by 2001kdx
My name's Ron!
