Page 1 of 2
Fork Bleeder Screws
Posted: 08:45 pm Mar 09 2008
by N8Strine
Does anyone make fork air bleeder screws for the kdx forks?
Posted: 09:21 pm Mar 09 2008
by maicocpa
Are you talking about the air bleeder valves? If so, they are standard size so any will work. The shorter, the better, less handlebar interference.
Posted: 07:57 am Mar 10 2008
by krazyinski
they all leak and are easy to break and when you break one that fork becomes a worth less poggo stick. just my take on them.
Posted: 01:17 pm Mar 10 2008
by Mr. Wibbens
krazyinski wrote:they all leak and are easy to break and when you break one that fork becomes a worth less poggo stick. just my take on them.
They all leak? What are you talking about, screws or fork bleeders?
Posted: 01:47 pm Mar 10 2008
by scheckaet
Don't have any trouble with mine. i can see how you could break them in a nasty crash (MAYBE) and if you do break'em I'm sure you'd have other things to worry about
My 002
Posted: 01:55 pm Mar 10 2008
by Mr. Wibbens
Mine are pretty well protected, I'll take a pic in awhile. Need to go out and wash and unload bike anyway.
As far as leaking? They don't leak, until you want em too
Posted: 03:28 pm Mar 10 2008
by Green Hornet
Mine don't leak.....
Posted: 04:07 pm Mar 10 2008
by skipro3
If you worry about them busting off, and I've ridden with a guy that happened to, just take your stock screws and put them back in. What? You don't have the stock ones? Why? Do they take up too much space in your fanny pack?
BTW, mine don't leak. I've had 3 bikes with them and none of them have leaked. Well, when I push the button they do.
Posted: 04:09 pm Mar 10 2008
by skipro3
This brings up another question;
If I have bleeders on my forks and they release pressure when i push them, is that a pretty good sign my fork seals are good? Then why do I find fork oil on one leg when I still have pressure in both legs?
Posted: 04:12 pm Mar 10 2008
by Ondatrail
Posted: 04:13 pm Mar 10 2008
by scheckaet
A very slow leak maybe? Would explain the bit of oil on the leg and still hold pressure
Posted: 04:15 pm Mar 10 2008
by scheckaet
I believe there is another company that makes them even smaller (for those worried about breaking them), but can't recall where, anyone?
Posted: 04:26 pm Mar 10 2008
by Ondatrail
scheckaet wrote:I believe there is another company that makes them even smaller (for those worried about breaking them), but can't recall where, anyone?
Motion Pro too, only you need to tap into the cap
http://www.motionpro.com/motorcycle/too ... _fork_kit/
Posted: 07:38 pm Mar 10 2008
by Colorado Mike
So your oil leaks out on the fork leg but you still have pressure in the cap...
You ride with funny friends that squirt a little oil on the leg?
When my seal blew, you could hear the air suck in on rebound and the oil gush out on compression. When I disassembled, I had very little oil, and very much air.
Posted: 08:08 pm Mar 10 2008
by N8Strine
Moose makes some also that are alot shorter, I will prob go with moose.
http://www.motorcycle-superstore.com/2/ ... e-Kit.aspx
Posted: 08:12 pm Mar 10 2008
by N8Strine
Moose bleeders are half the height. Motion Pro's 22mm compared to Moose only 10.5mm high
Posted: 09:52 pm Mar 10 2008
by Dewey
Interesting, half the height and almost twice the price. Guess they don't sell them by weight or length !
Posted: 07:50 pm Mar 11 2008
by Mr. Wibbens
From the outside looking in
My barkbusters pretty much protect them
Looking down
Posted: 02:21 pm Mar 15 2008
by maicocpa
Wow, Mr. Wibbens, those are tall. Mine are about 15mm tall. They don't leak.
BTW, I was told by a suspension tuner never to bleed the forks unless the front wheel is off the ground so there is no pressure on the forks.
Posted: 02:36 pm Mar 15 2008
by Mr. Wibbens
Motion Pro makes some that are only 3/8" but they require drilling, tapping and end milling of the fork caps
