kickstarter tearing off!
Posted: 12:55 pm Jan 03 2008
by binkaz
i'm thinking of welding it back and reinforcing it.. any idea how to remove the pin securing the kickstarter arm? wad tools do i need? can just use a plier?
Posted: 12:58 pm Jan 03 2008
by scheckaet
You're proly better off buying a FRP kickstarter...
Posted: 03:23 pm Jan 03 2008
by kdxquebec
binkaz,
I think your kickstarter assy is totally shot. The big washer under what you call a ''pin'' is rounded/ worn.Did your kickstarter was floppy or very loose before? You need a new kickstarter and a new boss.
Posted: 10:53 pm Jan 03 2008
by binkaz
thanks for your replies man.. mine is a kdx220sr.. would it be able to fit the frp kickstarter made for kdx220r? any reccomendations of where to buy with international shipping?
Posted: 11:07 pm Jan 03 2008
by binkaz
Posted: 10:45 am Jan 04 2008
by jc7622
Which model KX kickstarters will fit on a KDX?
Posted: 12:23 pm Jan 04 2008
by binkaz
binkaz wrote:http://www.ronayers.com/browseparts.cfm ... 13064-1174
is this a frp kickstarter? :?
anybody knows?
Posted: 04:04 pm Jan 04 2008
by Ondatrail
binkaz wrote:>|<>QBB<
anybody knows?
No FRP is after market:
http://www.frpoffroad.com/catalog/details.aspx?ProdID=7
Posted: 06:47 pm Jan 14 2008
by canyncarvr
RonAyers does have an online OEM lookup. That's what's shows in the RonAyers link, isn't it?
As said already..replacing a kicker without replacing the knuckle (boss...pin) is going to be a waste of your time AND your money.
There are KX kickers that fit the 'H' model KDX..an '89 KX125 'fer example.
Still, putting a 'good' kicker on a worn knuckle isn't useful.
IMO..get a new knuckle and an FRP kicker. A new knuckle does not come with o-rings, btw. It's next to impossible to make the OEM o-rings fit, anyway. Buy some thinner rings at your local hardware store...or trim the OEM rings. That takes a sharp exacto and a steady hand.
The ring-fit comments from when I put my FRP kicker on..and that was a few years back.
'Back when' even!! :shock:
Good luck.
...wouldn't bother trying to weld that junk, either. It'll still likely bend after it's patched up. Maybe it's bent now!.
