Replaced some parts...
Posted: 10:44 pm Oct 28 2007
by m0rie
Replaced my shift shaft which had stripped out completely. Pretty easy job if you take your time. Between it and the new shifter there is zero slop now in my shifting. Feels nice and tight and very responsive. Much nicer than it used to be. Also switched out my tweaked 7/8th inch Renthals for a set of Fat bars and at least from my lite riding around the yard i'm sold on Fat Bars. Seems like a great deal of the vibration that I used to feel in the bars is gone now. All in all a couple of much needed improvements.
Posted: 10:53 pm Oct 28 2007
by strider80
Do you have to pull the clutch to pull the shifter shaft? Mine is about clapped out.
Posted: 10:58 pm Oct 28 2007
by m0rie
Yep, everything on the clutch side needs to come off.
Posted: 11:52 pm Oct 28 2007
by strider80
Engine cover too? Not just the clutch cover?
Posted: 12:08 am Oct 29 2007
by m0rie
Yeah, _everything_...Drain the coolant, pull the water pump, clutch and engine covers. PITA but not too hard over all.
Posted: 05:56 am Oct 29 2007
by Jeb
M0rie - If you don't mind me asking what did ya' end up spending, total, when you went to the 1&1/8 bars? I was considering fabbing/installing a singe-tank subtank - a custom kind-of-thing, others have done it, where oil can drain back down into the forks. There's really not enough room with the 7/8 bars to do this so I was a 'wondering . . .
Posted: 10:47 am Oct 29 2007
by IdahoCharley
Jeb wrote:M0rie - If you don't mind me asking what did ya' end up spending, total, when you went to the 1&1/8 bars? I was considering fabbing/installing a singe-tank subtank - a custom kind-of-thing, others have done it, where oil can drain back down into the forks. There's really not enough room with the 7/8 bars to do this so I was a 'wondering . . .
Not MOrie here but - There are simple bar risers available from Rocky Mountain for about 20 bucks that will raise your bars and give you enough access room so you can install a fittings on top of the fork legs. Sub-tanks seem like a good idea which I'm also thinking about.
Posted: 11:00 am Oct 29 2007
by m0rie
When I bought my clamps for the KX conversion I got 1 1/8th mounts in the deal. Ski gave me some adapters for my bark busters and the bars were Longhorn cheapies from Rocky Mountain MC ($30 on closeout).
Posted: 06:28 pm Oct 29 2007
by Jeb
Rocky Mountain bar risers: SMACK! (that's the palm of my hand hitting my forehead) I was pondering on those anyway for more bar height to suit aggressive riding stance a little better but they'll double as making more room.
RE: Closeout cheapies - that's the way to go, I'm always on the lookout for something myself!!
