Radiator leak
Posted: 11:30 pm Oct 10 2007
Well, I had to go and screw with the bike, now didn't I?
Maybe if I hadn't I would have discovered the leak out in the woods.
Here's what happened:
I decided to install my Devol radiator braces. The Works Connection braces haven't arrived yet. I took the shrouds off and noticed that the throttle side radiator was mashed in to the 2nd fin. No biggie, I've tapped them fairly straight before using a block of softwood and a rubber mallet. About 3 blows on the thing and I stopped and thought to myself that hey, it's not leaking now, but what if it starts while I'm trying to "repair" it. About then I saw the drip. Too late. A drip surfaced not where I was tapping or the outside edge where the fins where so smashed in, but at the bottom, inside, front edge. Right where the fin that has the mounting tabs connect to the bottom tank.
Cut to the chase: I removed and using soap, lung pressurized and saw bubbles in the suspected spot. Way inside behind the fin at the base of the tank. I had a small butane torch and heated that spot up real, REAL good. cooled her off and tried the bubbles and mouth again. No bubbles!! Next to the garage, some tape to plug holes and the air compressor. Pressurized up until the cap vent started to whistle like a tea kettle. About then one of my tape plugs shot out like a missile. No bubbles though!! Did it again; air whistling out the overflow pressure relief vent and no bubbles in site.
So, think it's fixed? I think I just had a cracked solder joint and by heatng I reflowed the solder well enough to stop the leak. I want to ride and I don't know of any place local that will repair a motorcycle radiator tomorrow. I'm hoping it holds while carvr is here. In the meantime, If I can find one in a local dealership, I'm using it.
Anyone want to overnite me their KX250 cap-side radiator as a loan for a few days?? Ha!!
Let me know if i should do anything else. I was thinking about one of those radiator stop-leak concoctions you can buy at an auto parts store. Anyone have any luck with those?
