hard to start
Posted: 08:38 pm Aug 09 2007
by danbra
Hey guys, I just changed my oil and spark plug(didn't need to), usually it started in the first kick, however the start right after the change was a bitch to get going!!! is this normal??? will it go back to first kick start? thanks, Dan.
Posted: 08:45 pm Aug 09 2007
by Rick
As long as the oil level is correct, take that out of the equation. Is the new plug the same brand/# as the old? Is it gapped properly?
Posted: 08:46 pm Aug 09 2007
by IdahoCharley
Not normal - should start-up as easy if not easier than it did prior to spark plug change.
P.S.Make sure you cap is snapped onto the plug.
Posted: 08:53 pm Aug 09 2007
by m0rie
Check the gap on your new plug. Make sure it sparks when grounded to the frame.
Posted: 09:15 pm Aug 09 2007
by danbra
I set the oil a litle higher then before and the plug is the same as the old, stock one, I'll take for a spin sat and see how it goes!!!
Posted: 09:20 pm Aug 09 2007
by Rick
It should be OK. Let us know...
Posted: 09:50 pm Aug 09 2007
by Mr. Wibbens
fuel?
maybe even water in fuel?
nothing makes starting harder than a tiny amout of water in the carb bowl
Posted: 09:55 pm Aug 09 2007
by Indawoods
Why did you put water in your gas when you changed your oil and plug?
Posted: 10:15 pm Aug 09 2007
by 2001kdx
Hit up the basics:
air filter
gas
carb
plug
Posted: 06:45 am Aug 10 2007
by marco220
If the only things you did were oil and plug, put the old plug back in and see what happens -- if it fires on the first kick you've isolated your problem.
