Where can i find instructions for xr400 spring install?
- cleoent
Hi All, I fear i haven't gotten the hang of the search function on this forum yet, i get soo many results no matter how many keywords i type in.
Can someone link me to a good walkthrough on the xr400 spring install? What should i use for spacers, how do i empty fork oil, what to use etc...
Thanks so much in advance!
-Leo
-Leo
saddletramp
Try this one, I was able to get thru it with CC's help.
http://www.kdxrider.net/forums/viewtopi ... highlight=
1996 CR 250
03 RM 65 2000 YZ 80
1996 CR 250
03 RM 65 2000 YZ 80
- cleoent
i'm a 190# rider. I got the .38 weight springs from a 98 xr400, not the .40's. I ride a lot of single track, little bit of track just for fun, any idea of a good fork oil and preload to go with. I'm thinking a 3mm preload.
I also have no idea how to get to the springs, that thread never said nuttin about it. This will be my first adventure with suspension.... any tips would be helpful.
- KDXer
saddletramp
- cleoent
hmmm, not sure what that's a link for... it takes me to a page where there's pics of a bike with pinkish graphics, and 3 smaller pics of a wheelie and some jumpingKDXer wrote:http://www.dishers.com/index_Dirtbikes.html
nykdxer
- cleoent
- cleoent
ok i did it! Just wanted to make sure i did it right.
Took out old springs and top washers popped in new springs and top washers. Measured 61mm to the top of the fork, i made a 65 mm spacer which gives me 4mm of preload right? Definitely feels a bit better just from pushing up and down on it, took about 1/2 hr or so.
HOpefully tomorrow after work i can sneak some time to head out and try it on the trails! I didn't touch the fork oil, i figure one thing at a time.
saddletramp
- cleoent
saddletramp
Sorry bro if I had a e-series I could help a little more, not sure how your fork configureation is. Sounds like your on the right track though. Spacer needs to be long enough to compress the spring the desired amount with the cap threaded in the tube.
1996 CR 250
03 RM 65 2000 YZ 80
1996 CR 250
03 RM 65 2000 YZ 80
So...where did the length of the fork cap go?I measured from the top of the spring washer, to the top of the fork without the cap on, then made the spacer 4mm longer, that's not gunna work eh?
The information is in the threads listed. I just read them again to be sure you would have what you need.
You do.
That is correct.You measured from the top of the spring washer to the bottom of the fork cap, with the cap threaded all the way down on the damper rod right ?
The 'rod' (damper or not) referred to is the only piece you can see in there that the fork cap threads onto. Well, as opposed to INto. The question is written in such a way it explains itself.
Your spacer provides likely more preload than is needed...20mm or so.
Did you transfer the bottom clips off the old springs to the new springs?
If you didn't, your preload will be a bit more than you measured.
saddletramp
I'M not tradin' with anybody....
