1173 to a CEL
Posted: 05:51 pm Apr 30 2007
by saddletramp
I am currently running a 1173 clip in 3rd groove, 155 mj 40 pj. I am getting lots of spoo but runs great through-out, lots of 2nd gear grunt. Also I am mixing at 32:1 as I share gas with my kids walnut sized piston in his 65 (No spoo). With temps. warming I know it is time to lean out the jetting, so when I put the CEL needle in should I go ahead with a 152mj 38 pj? I know it is best to make one change at a time, but if the CEL is gonna let more gas in there it only makes sense. I tried reading the graph on needle tapers, but I am not real clear on it. Oh yeah, the 1173 would be a BP, where is a good position for the needle clip too, Thanks
Posted: 05:55 pm Apr 30 2007
by m0rie
Just swap the needle to start and then the jets from there. Start in the #3 clip position for the CEL.
Posted: 08:12 am May 02 2007
by G22inSC
I am still trying to sort out my jetting on the 200. I have heard several people recommend the CEL needle over the stock needle. Why is this? What are the similarities and differences?
Posted: 09:30 am May 02 2007
by Jeb
Before I had the RB mods done, I swapped the stock needle with the CEL. Better throttle response, snappier midrange power.
The taper of the needle is different - more gas sooner.
Posted: 11:16 am May 02 2007
by G22inSC
"more gas sooner"
So does that mean I would need to lean out the lower circuits or leave as is?
Posted: 11:17 am May 02 2007
by saddletramp
Well maybe I will wait untill things dry out before I swap needles. If more gas sooner means more wheel spin when I need to tractor thru on the quad rutted clay "Brown Ice" trails. Wheel spin usually results in the back wanting to pass the front and me on my a$$.
Posted: 07:24 pm May 09 2007
by saddletramp
Well the CEL deffinetly fattened things up..way to rich I even dropped the needle to #2 still could not get my a/s tuned. So back went the 1173 with a 38 p/j 153 m/j still grinning like a dufus. I even got poorman RB'd (thumbscrew adjuster) nice.
Posted: 03:24 pm May 10 2007
by 2001kdx
Yeah I too have found that the CEL or DEL will richen things up significantly. I just have to decide which needle to use - strong mid-range punch or smooth tractability.
Posted: 10:42 am May 11 2007
by G22inSC
How much richer is the CEL needle? Are we talking drastic changes or minor tuning?
Posted: 11:21 am May 11 2007
by m0rie
You'll need a couple sizes smaller jets to make it work right.
Posted: 07:14 pm Apr 20 2008
by ebeck
You are talking main jet smaller not pilot right?
Posted: 11:33 pm Feb 28 2010
by Tomm9050
What clip position?
Posted: 07:44 pm Mar 21 2010
by Tomm9050
What would be the best starting for jetting a CEL needle with
92 KDX
Fatty pipe
stock muffler
Boyesen reeds
no air lid
900 ft
70 degrees F.
Stock carb.
Thanks
Posted: 06:24 am Mar 22 2010
by Julien D
skip the CEL needle and use CGK instead for your 92.
Probably around 38-42 pilot and 150mj.
Posted: 05:41 pm Apr 13 2010
by Tomm9050
I have the RB'd head mod, same recommendation?
Posted: 05:48 pm Apr 13 2010
by scheckaet
cek or dek if you're RB'd
Posted: 06:20 pm Apr 13 2010
by Tomm9050
not the carb, (yet) just the head
