Thoughts on dented FMF?
Posted: 01:22 pm Apr 08 2007
by 2001kdx
I bought a fatty pipe a couple of months ago, i got it for cheap because of it's large dents. I'd like to know what you guys think, should I send it to Pacific crest or if it's even worth mounting a pipe guard in this condition.
I have not thought of it as pwer-robbing, because once it was jetted correctly, it really ripped.
Anyway, here are the pics:
Posted: 01:32 pm Apr 08 2007
by Mr. Wibbens
Here's the pix
Don't look bad to me.
Nice pipe mount
Posted: 01:46 pm Apr 08 2007
by Mr. Wibbens
This is a dented pipe
Posted: 01:47 pm Apr 08 2007
by AZRickD
You will find that your torque output from 2760 RPM to 2900 will be reduced by .3 foot pounds. Also, your max RPMs will be reduced by 150 RPMs.
Rick
Posted: 02:45 pm Apr 08 2007
by 2001kdx
the pipe mount was temporary... I had to weld the tabs to fit. It looks different now.
Posted: 03:31 pm Apr 08 2007
by thebleakness
This happened to a friend of mine on a ride 2 days ago. He pancaked it good, I couldnt stop laughing when he finally found it. Pictures dont give the dent justice.
Check these guys out if you want to get your pipe fixed,
http://www.piperepair.com/. Good price and they do awesome work.
Posted: 03:38 pm Apr 08 2007
by Mr. Wibbens
thebleakness wrote:This happened to a friend of mine on a ride 2 days ago. He pancaked it good, I couldnt stop laughing when he finally found it. .
Found it?
Posted: 03:58 pm Apr 08 2007
by thebleakness
Found it?
The dent, he didnt know he had dented it untill we saw it. That trail is a heaven for someone with a trials background. If you enjoy hopping over boulders for 3 miles straight then come out and try it.
Posted: 07:37 pm Apr 08 2007
by tag220
Two weeks ago I to shape my pc pipe with a rock
looked like 2001s pipe . I wanted to fix myself 40-60psi and torch works but not pro and you can tell
Posted: 10:06 am Apr 09 2007
by KDXer
Fill it with water and stick it in the deep freeze. The dents should pop right out as the water expands. Let the pipe sit in the sun to thaw, give it a good coat internally of WD-40 or similar, drain it and also let sit for a while before re-fitting. You may need to repeat the cycle fill, freeze and thaw a few times if its a bad dent but it does work.
So does a torch and PSI but the thought of an exploding pipe blasting hot blobs of FmF metal all over me isn't very inviting.
Posted: 05:29 pm Apr 09 2007
by crazyaboutriding
[url=
http://www.kdxrider.net/forums/viewtopi ... 0567#40567]
[/url][quote="KDXer"]Fill it with water and stick it in the deep freeze. The dents should pop right out as the water expands. Let the pipe sit in the sun to thaw, give it a good coat internally of WD-40 or similar, drain it and also let sit for a while before re-fitting. You may need to repeat the cycle fill, freeze and thaw a few times if its a bad dent but it does work.
[/quote]
how do you retain the water?
Posted: 05:44 pm Apr 09 2007
by crazybrit
There is a guy on eBay who's been selling 2stroke pipe repair kits for ever. They look to be good quality and everything I read said that you really do need a regulator on the plug that attaches to the end of the pipe. Even if you have a regulator on the compressor you want the backup on the pipe as too much pressure can be really bad.
This said, the whole concept of heat, oxygen and the carbon buildup inside the pipe freaks me out.
Local guy to me uses compressed argon, I think he charges like $35.00. Most cities of a decent size have some guy in a bunker who repairs them, saves on the whole 2 way shipping charges.
I'd be real curious to hear from anyone who's use the eBay kit. I guess if you keep the pressure low (many people find plugging the ends and the pressure from the heat to be enough) it would be ok but I'm fond of contiinued breathing
Posted: 07:47 pm Apr 09 2007
by tag220
I think I can still breath dose that make it ok?
Posted: 10:37 pm Apr 09 2007
by KDXer
crazyaboutriding wrote:how do you retain the water?
A whole lot of Sodium and MSG will help retain fluid. Other causes are CHF, horemonal imbalences, renal disease, circulation problems, obesity, lymphatic dissorders and so on and so on. Start eating poorly and don't limit your sodium intake. That oughta do it...
OH sorry 'that' water....
Seriously though, no need to plug the ends as long as you sit in it the freezer right it won't leak out. You may need to use some wire or similar to help it sit right. I used a bag of ice under the pipe as an adjustable stand so to speak, if that makes sense. I have heard by sealing the ends you can put too much strain on the pipes welds as it expands.
Posted: 01:41 pm Apr 10 2007
by fuzzy
