So my KDX pees like the rest of them, is it okay to set the float level to greater than 18mm? It is already at about 17.5mm.
Do I have this right, turn the carb upside down, then have the float just touch the needle pin and measure this distance from the bottom of the float to the carb base?
Float level, >18mm okay?
- strider80
IdahoCharley
Don't know that this will help you - but my check for the correct height of the float is to lean the bike over to about a 45 degree angle slowly. It should start peeing near 45 degrees. If it starts peeing at 30 degrees I drop the float some - if it is not peeing close to 45 degrees I raise the float a little. Real scientific - yah
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
17.5? That would be .020" difference?
That would be about no difference.
It's fine, though. So is 17 or 16mm.
Re: 'Do I have this right, turn the carb upside down, then have the float just touch the needle pin and measure this distance from the bottom of the float to the carb base?'
I think ICs method works better!
..but, yeah. Be sure not to load the pin spring at all.
It's also important to have free movement of the float. No rubbing on anything, both floats the same..stuff like that.
Several times I've heard the, 'It never USED to do that!'..pee..while sitting there.
Then, after a brazillion questions and the Spanish Inquisition it's determined that something else never USED to be like that, either.
A kickstand that used to be 1/2 way useable is now a pretzel, bent, worn out or some other fashion of 'not right'.
- Mr. Wibbens
all this was just covered pretty well in another thread but of course I cannot find it
