Reeds
Posted: 06:55 pm Feb 21 2007
by KDXforlife
I really feel stupid asking this but what are reeds and where are they on your bike and what do they do
Posted: 07:58 pm Feb 21 2007
by TopperHarley
your reeds are located on the intake side of your engine between the carb and your cylinder. they actually sit inside of the cylinder intake. Basically they acy as a one way valve. Allowing intake to flow into the combustion chamber and then closing off combustion from going back into the carb. Do you have a manual?
Posted: 08:52 pm Feb 21 2007
by 2001kdx
If they're split, repacle them! Get boyesen 607 reeds! Maybe vf3 reeds if your REALLY crazy!
Posted: 08:54 pm Feb 21 2007
by Jeb
No need to feel stupid . . .
Refer to the circled section in the graphic below. The assembly 12021 is often called the reed cage assembly. The piece sandwiched between the block (big piece on top) and that curved piece on bottom (affectionately known as "duckbills") is the actual reed. TopperHarley's description is well put.
These reeds as shown, by the way, are something you can change for improved throttle response and power. There's a couple of options. Do searches for "607" and "power AND reed" as well as "vforce" to get lots of info.
**EDIT** - I forgot: there's a multi-petaled reed and a duckbill on both top and bottom of the block (not shown clearly on the drawing).
Posted: 11:13 pm Feb 21 2007
by canyncarvr
A pretty much btw...but the reeds control flow to the crankcase...not the combustion chamber. What they are closed to is backpressure from the crankcase when the piston is moving down and forcing air/fuel mixture from the crankcase through the transfer ports
to the combustion chamber.
Well, you'd better hope so anyway!
Posted: 05:51 am Feb 22 2007
by Jeb
kdxforlife - Click the link below, source is wikipedia.org.
http://en.wikipedia.org/wiki/Reed_valve
Note the mention of "multi-staged" reeds? THAT'S the power reeds many replace their stockers with - the 607s!!
. . . and here's another, source is howstuffworks.com - it does rather well to illustrate/amplify CC's comment . . .
http://science.howstuffworks.com/two-stroke2.htm
Posted: 11:57 am Feb 22 2007
by canyncarvr
Re: How stuff works...
..where's the KIPS....??
