Do you put grease in the airbox?
Posted: 09:32 pm Feb 19 2007
by jhard527
I have an 86 KDX200 that I've been cleaning. I took the airbox out and apart and it looked as though there may have been grease between the element holder and the airbox. Anyone think that this is anything more than a dirty bike or is a grease bead between the two SOP? Any help is appreciated.
Posted: 10:00 pm Feb 19 2007
by Indawoods
That's what your supposed to do to keep dirt out.
Put the oiled filter on the basket... grease the element rim where it contacts the airbox to get a good seal.
Posted: 10:29 pm Feb 19 2007
by jhard527
Actually the grease in question was behind the circular plastic piece that holds the aircage with wingbolts. Normal?
Posted: 11:02 pm Feb 19 2007
by Indawoods
If you had an air gap there... then I can see why it was there.
Maybe time for a new filter?
Posted: 11:57 pm Feb 19 2007
by IdahoCharley
jhard527 wrote:Actually the grease in question was behind the circular plastic piece that holds the aircage with wingbolts. Normal?
Some bikes are noted to leak air and dust in this area bypassing the air filter. The addition of either weatherstrip sealant, or a fuel resistant RTV sealant, or a compressible foam or rubberized type gasket is a typical fix for sealing up this area. Grease would not offer as longterm sealing as would the others but in a pinch or for a short term solution it would be better than nothing IMO.
P.S. As Vince points out gease on the base foam portion of the air filter is also for a similar purpose.
