EFM auto clutch question ??
Posted: 08:39 am Dec 25 2006
by KDXer
Just wondering what I need to send to Garry ?? Basket ?? Basket and plates ?? I won a clutch assembly on ebay and just wondered what exactly I need to box up when it comes time to send it...
Cheers,
Trev...
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... :BCA:AU:11
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... IBSA:AU:11
Posted: 11:11 am Dec 25 2006
by skipro3
Trev,
I sent EFM everything, including all the washers, spacers, plates, etc. Even the clutch cover. (He will install a plug where the lever arm goes through the cover.) That way, I didn't misplace anything and when Garry sent it back, I had everything assembled in the order I knew it needed to be in when re-installing it. When I got the clutch back, I just spread everything back out and installed everything in it's proper order.
Good Luck!!
BTW nice buy on those auctions!!
Posted: 11:20 am Dec 25 2006
by KDXer
Awesome, thanks Jerry. Do you know if he supplies new plates or whether thats additional to the price ??
Posted: 02:40 pm Dec 25 2006
by skipro3
He did not supply new plates for me. I suppose he could with an additional charge if you wanted him to though. I got mine off eBay. Be careful in putting the clutch plates back in. I messed up and warped a plate due to inattention to detail. I think it's documented somewhere on this site.
Posted: 01:27 am Dec 26 2006
by KDXer
Thanks again buddy, I have read and re-read all your posts regarding the EFM and shouldn't have too much trouble come installation time. I think I will get a new full set of plates and send them along with it.
Cheers for the help Jez,
Trev....
Posted: 12:20 pm Dec 26 2006
by canyncarvr
I only read the EFM posts once..and I could have told you what to send, too.....
Holy Cow! That's a steal!! ..as long as the parts are OK. I hope you are going to take the clutch apart and at least look for cracks in the basket, especially at the bolt bosses. Make sure the threads are good.
I DON'T know what the famous inner/outer washer config is for the EFM. The two that are commonly missed/forgotten/lost? Don't miss that snafu. Come to think of it, you already experienced that issue, right?
If you're going to put in new plates, certainly get them now! Obviously the setup of the autoclutch will vary with plate thickness..might as well let Garry set the thing up the way you're going to use it. His advertised clutch price does NOT include plates. His website used to say that.
Website looks different. I'm sure his work is better than his webmaster's spelling!
I'm anxious to hear how you like it!
Going to a hand operated rear brake?
Posted: 01:45 am Dec 27 2006
by KDXer
canyncarvr wrote:I only read the EFM posts once..and I could have told you what to send, too.....
Well the biggest problem I have is I think my memory bank is FULL...
I mean the more I read/learn the more I seem to forget. I tend to skip alot of stuff with the mentality that its there to search when I DO need it. Like that thread of yours about fuel/oil ratios, I've read it but if I tried to understand it I'd be lucky to remember how to tie my shoes once done.
It makes my head hurt.
canyncarvr wrote:Holy Cow! That's a steal!! ..as long as the parts are OK. I hope you are going to take the clutch apart and at least look for cracks in the basket, especially at the bolt bosses. Make sure the threads are good.
Yeah I thought it was a bargain too.
I certainly will be checking now I know what to look FOR.
Thanks. I will also clean it, file the fingers if needed and remove the old plates prior to shipping.
canyncarvr wrote:I DON'T know what the famous inner/outer washer config is for the EFM. The two that are commonly missed/forgotten/lost? Don't miss that snafu. Come to think of it, you already experienced that issue, right?
Nope wasn't me. It twas me who couldn't figure out how to get to the big nut holding the basket on, off.
Yanno that lil bearing thing that just sits in there.
Is one of em the one that tends to stick to the back of the basket ?? The other one being ??
**EDIT** These ones ?? P/N 92200-1238 ??
canyncarvr wrote:If you're going to put in new plates, certainly get them now! Obviously the setup of the autoclutch will vary with plate thickness..might as well let Garry set the thing up the way you're going to use it. His advertised clutch price does NOT include plates. His website used to say that.
Cool thanks for that also, I anticipated new plates would be in order or on order.
canyncarvr wrote:I'm anxious to hear how you like it!
It will more 'n likely be mid-end of 07 but you WILL hear about it.
canyncarvr wrote:Going to a hand operated rear brake?
Of course... hehehe
Posted: 04:26 am Dec 27 2006
by KDXer
Posted: 05:26 pm Dec 27 2006
by canyncarvr
As long as you're sending it in, IF it needs to be filed on, ask Garry to do it. That way it will for sure be square, flat, straight and all that stuff.
He may well 'true' the basket fingers as PART of his process.
1. I'd expect a lot of baskets he gets are notched at least SOME.
2. He's likely to realize that returning a product that works is his best advertisement, so why return a clutch that has dented fingers?
Didn't look up the part numbers, but there are TWO washers that are often problematic (due to the worker person). One 'outside' (under) the basket, one on the INside of the basket.
I would assume the OUTside washer goes back in. Don't know if the INside one would. Ski's write-up on it probably covers that.
Yeah. My memory bank is full, too!! There is barely room for
both things I remember IN there!! Everything else just kind'a piddles out onto the floor. That makes me pretty much always standing in a puddle'a piddle.
Posted: 06:46 pm Dec 27 2006
by KDXer
Thanks for the help Brad and Jerry.
Much appreciated.
Posted: 06:53 pm Dec 27 2006
by Indawoods
Guess ol KDXer lost the strength in his clutch hand.
There has to be an exercise for this!
Posted: 07:04 pm Dec 27 2006
by KDXer
Posted: 07:25 pm Dec 27 2006
by canyncarvr
Ski is the one that knows the EFM clutch. Be sure to run engagement questions thru him. As I recall he ended up with different washers in different places AND installed in different directions to get his autoscrunch working to his satisfaction.
His 250 clutch seemed to work great near as I could tell...from a distance...watching him ride it.
....he never let me touch the thing!
Posted: 12:21 am Dec 28 2006
by skipro3
I offered. I just didn't insist! Ha!!
Trev, your KDX is modded enough to manage the autoclutch just fine. Once you get it, read closely about how to set the engagement point using the spring washers. (a spring washer is a washer that looks warped.) Also, read carefully on the DIRECTION the warp goes when adding or removing any while adjusting.
Also, don't do what Doug did; put two steel plates back-to-back. Ha!! He dang near melted that clutch cover on his KX500. Ended up only discoloring the plates a little before we corrected the problem. (25 miles of riding). That kind of tells you how strong and sturdy that autoclutch is if a KX500 can't destroy it even if assembled wrong.
Hand rear brake is awesome. No one will be able to touch you on technical trails...... unless they are Americans of course!!!
BTW, come to California around May or June. I'm planning a little party.
Posted: 03:32 am Dec 28 2006
by KDXer
Cheers Jerry. It will be a few months before it gets sent to Garry. I am trying to take as much in as possible to save you from the dumb questions come installation/setup time.
I was kinda hoping it would come back from Garry ready to bolt in and go as I am yet to tackle a clutch swap. I think I have read enough to get through it relatively unscathed though.
Thanks for the invite Jerry, we will have to wait and see how things go in the new year. Your probably sick of hearing me say this but.... Mel and I wish Denise and yourself the very best of luck with the new development and our kindest wishes for a happy new year. You guys deserve it.
I am really contemplating replacing my KG-35 with a KG-30 and replacing my VForce2 with a VForce3... What do ya's reckon, worth it ??
Posted: 11:19 am Dec 28 2006
by m0rie
I think you'd have to work harder at holding on...
Posted: 02:04 pm Dec 28 2006
by canyncarvr
May or June?
I thought the party was late summer!!??
Oh...I get it...the three months AFTER the fact is when I'M supposed to show up!! After it's all over!!
KayD..I think you will enjoy the -30 better with your bike modified to run as well as it does on the bottom-end. Well, I do anyway.
V-Force3? Absolutely!!
As long as you hijacked your own thread....do you know how your -2 was configured? There are hi/lo tension reeds AND hi/lo tension stops.
I don't mean you ADJUST the stops..there is that TOO. I mean there are completely different stops that themselves have a hi/lo adjustment.
They didn't 'come' that way, but I much preferred the lo/lo/lo (lo reed, lo stop set TO lo) setup. Yes, I tried the others.
