Bent needle
Posted: 03:41 pm Dec 04 2006
by radonc73
I have a 93 KDX 250 that the throttle sticks. I have visually inspected my carb. I didn't see anything wrong with it but is it possible to have a bent needle that wont seat right but looks straight. I am not a mechanic and want to get this straightened out before I take it into a shop and get charged $65 a shop hour for a needle. The throttle sticking has me a little afraid to ride it. I have wrestled with this for 5 years and everytime I think I have it fixed it sticks again. This is my last call for help before the shop.
Posted: 03:59 pm Dec 04 2006
by m0rie
Make sure the spring under the throttle cable cap is seated correctly.
Posted: 04:10 pm Dec 04 2006
by scheckaet
Is it lubbed good?
when you remove it from throttle and carb, does it still stick when you pull on the cable? Do you feel any resistance?
Make sure the throttle is clean and DRY (no grease)
Posted: 04:56 pm Dec 04 2006
by Indawoods
5 YEARS????
Man... just get a cable luber.... clean it, clean it again... and one more time for good measure. Pull your throttle tube and clean under it with some brake cleaner and clean your throttle tube with some WD and wipe it dry. If all that fails... Buy a new needle... all under $10
Posted: 05:13 pm Dec 04 2006
by radonc73
I have changed throttle cables, moved needle positions, lubed the cable with a cable luber gizmo. It would be fine for a few months then stick again. I took almost a year and a half off after back surgery (not related) and then planned a wedding so I really haven't had money or been very good with my maint.
my brother was doing most of it but he is stumped with this one. When it stuck last I tried killing it and restarting it. It stuck the first 2 times then it was fine. It only seems to do it when I have it WFO and then it hits and doesn't let go after I do. I am not a fulltime rider more like every few weekends so I don't have many hours on it especially in the last few years but I really like the bike but the throttle seems to take the fun out of it. And that is what it is all about.
Posted: 06:05 pm Dec 04 2006
by Colorado Mike
Take the carb off the bike, reconnect the slide to it. open the throttle all the way. and roatate the needle a little bit and see if it sticks, keep doing that till you've made some revolutions. You could also chuck the clip end of the needle in a drill EXTREMELY LIGHTLY and spin it at fairly low speed to see if it's bent. I also wonder if you have the right parts in the carb, like a needle too short, or something funky with the slide that makes it hang up.
Posted: 09:07 pm Dec 06 2006
by radonc73
I went out and went to messs with the carb and check the needle. I twisted my throttle and heard a distinctive click from somewhere in the carb so I think I will investigate that this weekend. Thanks for the advice everyone I wanted to have an idea of what to look for.
