Dimensions for yourreference: 2000 KDX and 2001 KX125 triple
Posted: 10:48 am Aug 08 2006
by strider80
I got the calipers out and made a few measurements last night:
KX upper triple hole ID= 25.03mm
KX upper triple thickness=20.27mm
KX stem OD at upper triple=24.95mm
KDX upper triple hole ID=23.54mm
KDX upper triple thickness=24.5mm
KDX stem OD at upper triple=23.42mm
KDX stem at lower triple= 30.15mm
KX stem at lower triple= 30.15mm
KDX lower triple hole= 30.13mm
KX lower triple hole= 30.13mm
Took 10 tons to press out the KDX stem!
Posted: 09:50 am Sep 08 2006
by AZRickD
Thanks for your data points.
Rick
Contemplating my own conversion since my KDX is set up for a 155 pound rider and I have at least 40+ on that, not including gear.
Rick
Posted: 11:51 am Sep 11 2006
by strider80
All I can say is do it! I can't believe I waited so long!
My 2001 KX125 front end with stock springs and valving feels great, (200-205 riding weight).
Posted: 04:56 pm Sep 11 2006
by tim
Rick
Do you know what spring weight the rear shock has? You said your kdx was setup for 155lbs. And are you going to replace it with 1 for your weight I might be interested in the lighter 1 or possibly a swap for a stock 1 from my 06 200.
Tim
Posted: 11:45 pm Sep 18 2006
by AZRickD
I don't know yet. I think it's the stock spring (what I'm told is for 180 pounders).
I'll e-mail QuailChaser to find out.
Rick
