This is new to me and I’ve never really looked at the Boyesen instructions. In there it says to flip them if needed when new to get them to sit flat. I’ve heard of people doing that to get a little more life out of them but never thought to check brand new.
I was installing dual stage pro series reeds on a bike and decided to check them by laying them on a granite counter and then pushing my fingers down where the screws go. The base petals with the large opening in them sat flat but the carbon fiber top petals definitely have a crown to them. Push down and the front raises up. Flip them over and they stay flat. Holding them on the cage with my fingers one way has light all the way across and when flipped over, no light at all.
I have a set of new super stock reeds on hand so decided to check those. They both have a side that sits flatter. I also have a set of replacement petals for my KDX V Force when I need them and those also have a side that sits much better than the other. We should check them out every time before installation.
Flipping reeds over
- Has thanked: 39 times
- Been thanked: 102 times
Re: Flipping reeds over
John says, "...check them [reeds] by laying them on a granite counter and then pushing my fingers down where the screws go."
And, thus, the failed methodology is exposed. Instead of a granite counter top, reeds should be placed on a slate billiard table for inspection!
- SKY7220LRG-1_91aeaa1a-30f9-42c9-a6e5-eb5ec08961e9.jpg (629.81 KiB) Viewed 29655 times
- Has thanked: 290 times
- Been thanked: 139 times
Hey, don't knock it! I use milled flat highly polished stone slabs as surface plates, as checking them with a machinist straight edge and feeler gauge has shown me they are impressively flat, nearly perfect, much to my surprise... And I have pretty darn high standards.billie_morini wrote: 03:18 pm Apr 09 2026 John says, "...check them [reeds] by laying them on a granite counter and then pushing my fingers down where the screws go."
I use floor sander sheets, the rectangular sanders, with a light even coating of contact adhesive from a fresh aerosol can, to hold them to the surface plate, and I have resurfaced many inline 4 cylinder motorcycle heads and cylinders this way with extremely impressive results...
- Been thanked: 4 times
I could see me now. Not only can we shoot some pool but I can also check my reeds. Just wait and see doll face, you’ll love it.
Chuck says, "Hey, don't knock it! I use milled flat highly polished stone slabs as surface plates, as checking them with a machinist straight edge and feeler gauge has shown me they are impressively flat, nearly perfect, much to my surprise... And I have pretty darn high standards.
I use floor sander sheets, the rectangular sanders, with a light even coating of contact adhesive from a fresh aerosol can, to hold them to the surface plate, and I have resurfaced many inline 4 cylinder motorcycle heads and cylinders this way with extremely impressive results..."
billie says, "Chuck ever remains my illustrious scientist friend."
- Screenshot_20260410_001338_Chrome.jpg (316.93 KiB) Viewed 29359 times
