E-series rear caliper piston size
Posted: 03:28 pm Sep 08 2022
by Duper80
Hi guys, I recently disassembled my rear caliper to clean and rebuild it but somehow lost the caliper piston
, does anyone know for sure if/what other bikes use the same rear piston? Or know the dimensions of it? The oem piston is like $80-$85 canadian with shipping so I'd like to find an aftermarket option, I'm thinking it's around 25mm diameter and 25mm-30mm long?
Re: E-series rear caliper piston size
Posted: 02:51 am Sep 09 2022
I think I would just buy a used caliper or check on the price. I know CA dollars don't go as far on dirt bike parts, though.
Posted: 07:22 pm Sep 09 2022
by JimmyB
I deleted my original reply as I found some more options, Click on the application chart for this piston 30mm x 31mm on link below, brings up the E series KDX rear caliper,lots of bike options...
https://www.mymotoparts.co.uk/p/caliper ... ch-283031/
Posted: 12:34 pm Sep 11 2022
by Duper80
KDXGarage wrote: 02:51 am Sep 09 2022
I've already cleaned and rebuilt my caliper so it's ready to go back on just need the piston, if I have to I'll bite the $80 bullet and buy the oem piston but it would be awesome if I could find another bike that uses the same piston so I can buy an aftermarket piston for $20-$30
Posted: 02:36 pm Sep 11 2022
Partzilla:
This Kawasaki 43020-1088 BRAKE PISTON fits the following models and components:
Aftermarket Parts Brake Brake Calipers Brake Caliper Piston
Kawasaki Motorcycle 1994 KDX200 - KDX200-E6 REAR CALIPER
Kawasaki Motorcycle 1990 KDX200 - KDX200-E2 REAR CALIPER
Kawasaki Motorcycle 1992 KDX200 - KDX200-E4 REAR CALIPER
Kawasaki Motorcycle 1991 KDX200 - KDX200-E3 REAR CALIPER
Kawasaki Motorcycle 1989 KDX200 - KDX200-E1 REAR CALIPER
Kawasaki Motorcycle 1993 KDX200 - KDX200-E5 REAR CALIPER
Posted: 03:42 pm Sep 11 2022
by Duper80
KDXGarage wrote: 02:36 pm Sep 11 2022
Partzilla:
Yeah that's where I buy most of my oem parts, I'm just trying to avoid paying $80 for just a caliper piston so I'm hoping someone can help with the exact dimensions/size of the piston so I can check if another bike uses the same one, but after doing so much research I'm almost positive it's an e-series specific part because it's not showing up in any of my cross reference searches
Posted: 09:42 pm Sep 11 2022
Yeah, I saw one on eBay that said it was for RM and 1995+ KDX. Sorry to not be of more help. Maybe you will find yours.
Posted: 10:06 pm Oct 06 2022
by Duper80
KDXGarage wrote: 09:42 pm Sep 11 2022
Thanks, I ended up finding my spare caliper at my brother’s shop but now I have another “mystery” issue lol.. the rebuild kit I ordered last year has seals that are too small
, not sure why but both the main seal and dust seal diameters were too small to be pressed into the seat/groove so I just cleaned everything up and put it back together with the original seals and… it absolutely will not bleed! Tried the normal way 1000 times, tried back bleeding with a syringe, tried reverse bleeding, even took the caliper off and tried bleeding it while it was higher than the master cylinder, I’m all out of tricks lol
Posted: 12:23 am Oct 07 2022
Is the piston moving? Any corrosion inside the bore possibly?
