brake line attachment?
Posted: 07:21 pm May 15 2006
by Colorado Mike
I'm putting on '03 forks and have the stock caliper and line. I got some stock fork guards that assume you have the KX brake line routing that goes down the front of the fork. I'd rather stick with the KDX routing, but need a way to attach a clamp to the guard. I've seen Ski's method, but he's got the high dollar Carbon Fiber fork guards, and mine don't seem stiff enough at all to hold the line in position, plus as the fork compresses , it would bind on the fork guard guide on the upper tube.
Anybody that has mounted it KDX style, how'd you do it?
thanks.
<edit> was spelling like a dumbass again.
Posted: 07:23 pm May 15 2006
by Ryan
mike if you figure it out let me know as i am doing the same.
Posted: 07:32 pm May 15 2006
by Indawoods
When I was deciding which way to go on mine.... I noticed that the brakeline being in the same position for 10 years kinda formed it that way and it didn't want to do anything but stay in perfect position... even while riding.... Go figure!
Posted: 07:43 pm May 15 2006
by m0rie
Mike - Just drill two holes at the edge and use ziptys to secure the brake line or pop rivet the brake line clamp sideways and use that.
Posted: 08:05 pm May 15 2006
by Colorado Mike
Vince, my bike isn't that experienced yet, but I'll experiment.
Morie, If I do that, then I have to take off the guide that the fork protector slides inside, otherwise it'll jam up. Right?
Posted: 08:12 pm May 15 2006
by m0rie
Yeah, you'll have to go sans guides. I don't think they are really needed though. My fork guards are plenty strong without them and a lot of bikes don't have the guides anymore.
Posted: 11:40 pm May 15 2006
by skipro3
Yup, loose the guides. Also, those carbon fiber guards aren't too expensive if you find them on eBay. I got mine for about $20, and I've seen them buy-it-now for about $50. They are hugely stiffer than the stock plastic ones.
If you mount a home-made bracket like mine, it helps the plastic ones become stiffer as well. You might find something like a late model guard would fit with some mods. Like the yamahas. If you could get your hands on a set cheap, it might be worth the try anyway.
Posted: 05:59 am May 16 2006
by bradf
CM, I did exactly as Ski and I used Acerbis plastic guards. I epoxied the back too, just like Ski.
Posted: 08:11 am May 16 2006
by Colorado Mike
yeah, I'll give making a bracket a try.
Posted: 04:59 pm May 17 2006
by canyncarvr
What. Two holes and a thai-wrap not good enough for you?
Racist or something? Huh? Well? :shock:
If you're looking for a line holder to bolt to that fancy-schmancy bracket of yours...take a look at the Yamaha clamp (any new blue).
Posted: 08:41 pm May 17 2006
by skipro3
I just re-used my stock KDX "line holder" AKA clamp with the home-made bracket.
Posted: 08:45 pm May 17 2006
by Colorado Mike
that's what I was gonna do (re-use the stock bracket), but since I'm so lazy, now I'm thinking zip-thai.
Posted: 11:22 pm May 17 2006
by skipro3
you guys are making me hungry.
Take some extra ties with you. You'll need it when one breaks.
Posted: 03:23 pm May 18 2006
by canyncarvr
The stock clamp is straight.
The Yamaha clamp has a curve to it.
