KIPS Help! Does this look right?
Posted: 08:32 pm Nov 22 2021
by Owyhee1
KDX220R- Millenium did a replate, cleaned pv. After new top end, bike won’t rev out. Removed advancer pawl and pipe, looked inside. When gear is cw, the sub valves open far enough to be seen in side ports. (See pic). I’m assuming this my problem?
Re: KIPS Help!
Posted: 11:31 pm Nov 22 2021
by bufftester
Which version of Service Manual did you use? Some of the older OEM ones had the valves backwards in the reassembly. That would lead to poor top end performance
Re: KIPS Help!
Posted: 11:35 pm Nov 22 2021
by Owyhee1
The KIPS was cleaned and reassembled by Millenium, is this what backwards looks like?
Re: KIPS Help!
Posted: 08:59 am Nov 23 2021
by ss109
If that is what is supposed to be the fully open position then it looks like they mistimed the sub-valves. It happens.
Re: KIPS Help! Does this look right?
Posted: 04:41 pm Nov 23 2021
That cylinder wall is quite lovely though!
Posted: 05:23 pm Nov 23 2021
by Owyhee1
Kdxgarage- do you agree? Are they miss-timed?
Posted: 07:00 pm Nov 23 2021
From what I remember of other people's pictures, I think it is.
Posted: 07:14 pm Nov 23 2021
Posted: 08:06 pm Nov 23 2021
by Owyhee1
Follow up, yep, sub valves one tooth off! Easy fix. Thanks for the help!
