E-series clutch question...
Posted: 06:35 pm Nov 01 2021
by ben990
I just picked up a 1994 KDX 200, and the clutch has the last plate lined up in the fingers of the basket, like this:
- 20211101_161755.jpg (2.68 MiB) Viewed 3735 times
In all my other KDXs, all of the plates have been lined up, like this:
- 20211101_161807.jpg (2.39 MiB) Viewed 3735 times
Which way should the plates be oriented?
Re: E-series clutch question...
Posted: 08:41 pm Nov 01 2021
by bufftester
The 94 is correct, all your others are not. From the service manual "Place the last drive plate on the outer tangs of the clutch hub"
That second clutch has some serious notching going on there that will need to be addressed.
Posted: 08:58 pm Nov 01 2021
Here's a 1995+ version on eBay. It may have never been apart.
I think bufftester is correct.
https://www.ebay.com/itm/363516439923?f ... 7675.l2557
Posted: 10:16 pm Nov 01 2021
by ss109
Why the last friction disc is was offset to the others from the factory makes no sense and makes no mechanical difference to clutch operation. Install it however you wish.
Posted: 08:44 am Nov 02 2021
by Slick_Nick
That last plate being offset is technically the factory installation method, however I don't believe it matters. Maybe has something to do with the judder springs? Most aftermarket baskets don't even have that provision.
Posted: 10:31 pm Nov 03 2021
Look up "notched clutch basket".
