odd cylinder size
Posted: 06:51 pm Nov 10 2020
well this is odd ,
1998 kdx220r ,basket case unknown condition
i took the cylinder off to check the con rod and piston .
it has a wiesco piston
and the con rod /crank seem good no decernable up and down play and very little side to side.
but the cylinder bore measures with a bore gauge bang on 69 mm with a small amount of ovality going to .007mm bigger.
i am sure its meant to be 69.025 to 69.041.
no marks in the bore either.
should i send it out and get it honed into limit.
whats your thoughts .compression was only at 75 but i think the rings were stuck..
the piston was worn to 68.8.
cheers mark
cheers mark
