96 klx650R Forks on 02 KDX200
Posted: 09:09 pm Jun 27 2020
by qbury
Hello,
I'm new to the forum and KDX's. Sorry to broach this subject yet again but I couldn't find any direct answer to this. I have found a set of forks and clamps from a 1996 KLX650R. I'm wondering if these are a direct bolt on replacement like the KLX300. Also will I need a wheel, axle and caliper or can I use mine for the KDX. Loving this forum thus far.
Re: 96 klx650R Forks on 02 KDX200
Posted: 12:19 am Jun 28 2020
Welcome to kdxrider.net. Thanks for joining AND participating.
Check the steering stem stop location, but otherwise I think they should bolt right on.
The caliper is the same, so you can use the one you already have, but the hose routing is different due to the forks attachment points and guards. A few folks have made a little clamp to keep the KDX style routing.
Check KLX300R threads on the wheel. I can't remember right now.
https://www.partzilla.com/catalog/kawas ... -klx650-d1
Posted: 09:04 am Jun 28 2020
by qbury
Thank you for the response. I did previously check some of the oem part numbers and a lot of them are the same. I'll need to find out about the wheel, brake line mounting and fork guards.
Posted: 09:37 pm Aug 09 2020
by XR1200
It all fits thats what I did with my 02 220
Posted: 01:14 pm Aug 14 2020
by qbury
Thank you. Good to know. I have all the parts. Just need to get around to changing them.
Posted: 05:56 pm Sep 27 2020
by K50X200
Do the KLX650 forks have compression & rebound adjustments, or are they compression only?
Posted: 07:12 pm Sep 27 2020
by qbury
K50X200 wrote: 05:56 pm Sep 27 2020
Compression only.
Posted: 08:18 pm Sep 27 2020
yep, compression only, like KDX or other KLX forks
another thing that is different to 1990+ KX forks is the cartridge size. (just 20 mm for non-KX)
