throttle response question for you
Posted: 11:26 pm Apr 20 2006
Recently I have been getting my bike to run much better with the experimentation of different needles and jets.
My question is that even when jetted well, will the KDX experience a bog somewhere in the power range?
For example, I have cut my slide to a ballpark 7. 38 pilot, 150 main. With a CCL needle in the 2nd clip, I can whack it open as fast as I can in second gear from 3mph and the bike jumps and goes. Air screw is 2/3 out here.
But if I am moving slightly faster and have the throttle open just a tid bit, like 1/16th to 1/8th, then roll it on a bit slower I get a quick bog. More like it cuts out for a millisecond or two, then goes. I played with the airscrew and tried different needles like the DEK, CCM, BEM, DGJ, EEL, etc. and I can get the bike to run great everywhere except for this little spot.
Quick snap open, as fast as I can move my wrist, no bog, bike goes, front end comes up. Very slow to medium roll on, smooth crisp acceleration, wheel lofts nicely and controlled. From 1/16 steady throttle,I get the dreaded bog then snap of power, medium roll on here. Not a crackle, definitely a bog, more like a "Waa..waaAAAPP!!"
The only thing I can think of is that I cut the slide more than a "7" and went too lean on it, causing the bog in the 1/16 to 1/8th range. A smaller diameter needle than a xxL loads up at idle and decel, and a larger diameter than an xxM produces a large long drawn out unridable bog all over the place. If I run the 40 pilot the motor loads up in the low end. If I set the pilot out enough so the motor doesn't load up, the bog worsens. Also, if I have the air screw less than 1/2 out, it will load up with the 38 pilot. Any thoughts? I wish I had Ron cut my slide, now I'm just guessing.
Other factors: 93 Pump gas Yamalube 2R 32:1, sea level 80* F, 20 hours on bike from new, Boyesen 607 reeds, Pro circuit plat 2, Clean air filter BR7ES plug, no airbox lid at all. Later in the summer, I will save enough to go with the RB mods including the head mod on my 200.
