87 Sperical bearing
69candy
- Country: Australia
87 Sperical bearing
Is there any replacement spherical bearings available for the 86-88 suspension arm? They want my left nut for a genuine one if you can find them. Must be something else that fits surely??? 14 x 27.7 x 17
- Has thanked: 185 times
Re: 87 Sperical bearing
All Balls I think
- Been thanked: 10 times
I could not find anything available from the commercial/industrial/aviation market that fits. Appears that Kawi only used it on a few models for a couple years. Best price I found on Ebay was 60$ You might get lucky and find a rod online for sale.
- Kdxfan4130
- Country: Usa
Contacted Kaman they could not find anything in that size. Everywhere on google says they are not available.
Possibly a used motorcycle parts dealer might have it off another bike as that brg was used in a few bikes back then
Restore rather than replace
I search by using a Crystal Magic 8-Ball.
https://www.allballsracing.com/27-1106.html
Ima teech y'all howta search, one deese days.
Long version:
You want 59266-1056, which is HIGH DOLLAR if you find one (or even two)
What does 59266-1056 fit?
This Kawasaki 59266-1056 JOINT-BALL,ROD Not Available fits the following models and components:
Kawasaki Motorcycle 1988 KDX200 - KDX200-C3 Rear suspension
Kawasaki Motorcycle 1987 KDX200 - KDX200-C2 Rear suspension
Kawasaki Motorcycle 1986 KDX200 - KDX200-C1 Rear suspension
Kawasaki Motorcycle 1985 KX500 - KX500-B1 Rear suspension
Kawasaki Motorcycle 1986 KX500 - KX500-B2 Rear suspension
Kawasaki Motorcycle 1985 KX250 - KX250-D1 Rear suspension
Kawasaki Motorcycle 1985 KX125 - KX125-D1 Rear suspension
Kawasaki ATV 1987 Tecate - KXT250-B2 Rear suspension
Kawasaki ATV 1986 Tecate - KXT250-B1 Rear suspension
Kawasaki Motorcycle 1986 KX250 - KX250-D2 Rear suspension
Does All Balls show those bearings for KDX200? NOPE. Are they available for 1985 KX250? Yes.
It also has swingarm bearings for the KDX in that kit (KX main link bearings).
We hope you have enjoyed this week's episode of "Shopping with KDXGarage".
Long version:
69candy
KDX garage. Thankyou. Here is another option I discovered today. The bearing has a part number on it. GE14ES/K1. Punch that into your search engine!! Only comes up in England, not Australia, but cheap!!!!
You're welcome.
Those bearings were not cheap from Kawasaki when the bike was relatively new. I bought a couple in the late 80's or early 1990's. I think I paid $22 or so, plus tax back then (plus labor to install).
targetman
SRRobirds
Re: 87 Sperical bearing - mounting bolts
Thanks for the lead for spherical bearings – just ordered them from All Balls for my 86 KDX200.
Has anyone found a source for the dogbone mounting bolts? I found the bottom one on eBay, but no joy for the top one: Part # 92002-1633.
Welcome to kdxrider. Thanks for joining.
I don't have a lead on that bolt. Sorry.
I might have an extra set, but I know the top one had wear from a seized bearing
I think with these linkage bearings one side of the bearing race and the sphere were flush, making this unique. That might’ve just been the shock bearing though, can’t remember if they were all like thatlucy wrote: 08:07 pm Dec 28 2019 Can you bore the diameter a little bigger to match an available part?
The 1988 bolt might work, if you can find one. I think it was the same, just with no grease fitting.
I think the swingarm bolt is the same way.
SRRobirds
Thanks for responses guys. I think the '88 had smaller threads than the '86 (12 vs 14mm), but a good thought. I think I'll just look for a 14x50mm bolt without threads except for the final few mm (which may be just as hard to find that as the original part!). I'll just have to disassemble it to grease it.
Thanks again.
Thanks again.
The bearing is the same for 1986 - 1988. The '88 bolt does need the '88 nut.
