Exercise in futility maybe
Posted: 05:56 pm May 04 2018
by jstcraig
So as we are all aware some parts are as rare as so I would like to ask of the forum the following.
This is off an early model KDX200 86/8, does anyone know how much difference there is to the 89-94 KDX200 ??
Re: Exercise in futility maybe
Posted: 11:51 pm May 04 2018
You keep asking questions like you have an "E", but you have an "F" or "G". :hmm: Most people on this site see 89-94 an think "E". Do you not have a different carb than the "E" model's 35 mm PWK Keihin??
Posted: 04:50 pm May 05 2018
by 6 Riders
Why don't you tell us what carb you have? It'll make helping you much easier.
If you have a 35mm pwk, then that Reed block won't work. Also, assuming you have the pwk, just buy a vforce or a rad valve and fit one of those.
Posted: 06:22 pm May 05 2018
The 1986 - 1987 USA KDX200 boot is different than the 1988 boot. In the USA, C model used Keihin PWK35.
Posted: 06:49 am May 07 2018
by jstcraig
6 Riders wrote:Why don't you tell us what carb you have? It'll make helping you much easier.
G’day I believe that it is a pwk28 the Venturi measures 28.5mm IO, the images of kits lead me to this conclusion, the confusion is due to the fact that any image from Partzilla and Kawasaki don’t match, even at the local dealer.
Jst had a look at an image of the pwk35 rebuild kit and that’s definitely not it.
There is PE cast on the side ???
Posted: 06:52 am May 07 2018
by jstcraig
Jason wrote:You keep asking questions like you have an "E", but you have an "F" or "G". :hmm: Most people on this site see 89-94 an think "E". Do you not have a different carb than the "E" model's 35 mm PWK Keihin??
Hi Jason, to be honest I’m not sure what I’ve got Sr, E ????, heading down the local dealer with a vin number, hopefully this will stop the inane questions although I don’t think it will[emoji16]
Posted: 02:08 pm May 07 2018
Post a frame number or BIN and engine number. I have the Model Identification Guides that dealers have.
PE is a model of Keihin carburetor. Many mid 80's MX bikes had them.
Posted: 09:36 pm May 07 2018
by jstcraig
Jason wrote:Post a frame number or BIN and engine number. I have the Model Identification Guides that dealers have.
Just found something online about the Sr having the PE28 and suggest’s upgrade to the pwk35 .
Posted: 06:59 am May 09 2018
by jstcraig
Here are the images of the frame and vin numbers, so it’s an F .
Posted: 02:30 pm May 09 2018
yep
1991 M
