Advice on which conversion to do
Posted: 11:07 am Aug 29 2017
I'm looking to get a quick turn around on the fork conversion so my options right now are drz250 or '91 kx 500. Maybe klx forks. I am mostly looking for rigidity as I like going fast through tight tech woods and need my bike to go where I point it quickly which leads me to the kx forks but everyone seems to think the '91s are still crap. Would I be happy with the drz forks? I know its an upgrade but is the flex still bad? Also I have a '90 kdx and I want fat bars so if I did drz swap would need kdx C or H top clamp. Anybody know if C clamp is the same as H? Its half the cost.
The kx swap is cheaper by almost $100 but would prolly require revalve(which I would attempt). I weigh 175 w/gear so I don't think I need diff spring weights for either (drz .38kg/mm, kx .39) So would I be better off waiting for newer kx forks? Would the drz forks be stiff enough? My reason for thinking in this direction is my stock forks need stiffer springs, the front wheel crawls up the sides of ruts then let loose or goes in another direction then where I point it (into trees) in muddy g-out type situations and I can't find anything but .40-.46kg/mm triple rate springs.
I would like a quick turn around but would hate to do something in a rush and then regret it later.
