Ughhhhhh stuck exhaust valve rod screw (KIPS)
black
so i finisihed rebuilding the rear shock and I'm up to now doing a top end rebuild and servicing the KIPS and replacing with ( never been done)
cyclepedia has been really good but....taking off the exhaust valve operating rod retaining screw using a #2 Phillips head screwdriver i a bug hurdle
It is on there tight!! tried using a#2 and also a #2 impact screwdriver but it is starting to round. Any ideas? heat? PB blaster? j
- Has thanked: 116 times
- Been thanked: 31 times
Re: Ughhhhhh stuck exhaust valve rod screw (KIPS)
JIS friendly screwdriver?
Vessel Tools Impacta
Keystone
I had to use an impact screwdriver w/ hammer to get mine off. you have to be careful though not to hit it TOO HARD and crack the motor, that would suck. I bought a couple brand new screws to re-install. I tried not to overtighten it when I reinstalled it and used some blue loc-tite. it's just a bitch.
black
Just tried the JIS. No go. I'm a little worried here. I'll try the IMpa t tomorrow morning again. Just hope I don't crack it. Ughhh. So close
- Been thanked: 10 times
black
For others in the future, check out the Impacta (yes, with an A) line from Vessel.
Heat and oil should help on this.
Willbilly
what bike is this for? I'm in the middle of rebuilding my top end and don't remember a phillips head bolt anywhere.
Keystone
Does that screw have a dimple on the head?
Keystone
- TheGriz
I used heat and penetrating oil a number of times. Each time I heated and oiled it, I'd give it a sharp impact with a small hammer to help break it free from the gunk.
1987 KDX 80
1991 KDX 200
2005 GasGas EC250
2011 GasGas EC300
2008 KTM 300
1991 KDX 200
2005 GasGas EC250
2011 GasGas EC300
2008 KTM 300
