1989 KDX need help with fork seals!
dirtbagrider
Post by dirtbagrider »
So today I started replacing my fork seals on my 89' KDX, all was going well, I took them off the clamps, drained the oil, took out the spring. After getting the forks unassembled and empty i couldn't figure out how to get the thinner silver tube out of the thicker lower casing (this is my first time replacing seals), I took out the small rubber cap out of the bottom of the fork and saw that there's a 14mm hex hole and then inside there is also a flat head screwdriver slot.. I was confused so I didn't tamper with them anymore.. So any help at all would be great! Or just what I need to do to get the inner tube to come out so I can replace the seals and clean out all the gunk!! Any help is greatly appreciated!
Has thanked: 126 times
Been thanked: 33 times
Re: 1989 KDX need help with fork seals!
Remove the circlip by the fork seals.
Get a 14mm hex bit socket and a fork damper rod holding tool or try to shove the end of a broomstick down in there, etc.
The point is to keep the damper rod from spinning as you loosen the compression damper assembly (where the 14mm hex fitting is).
6 Riders
Post by 6 Riders »
IRRC, you can remove the dust seal, then the retaining clip. Next put the lower leg in a vise, careful not to crush it, use the upper (inner tube) like a slide hammer to pop out the oil seal. Replace the bushings while you are in there.
patricktuller
Post by patricktuller »
I didn't have the tube holder, i just used an impact with 14mm Allen and used short bursts. The inside tube is screwed into the valve on the bottom. I was able to tighten the same way. I would think the problem with using a broom handle would be getting debris in the fork.
Sent from my SM-G920P using Tapatalk
dirtbagrider
Ok that makes sense! And what does the flathead screwdriver slot do?
That is the compression adjuster. LIGHTLY turn it. It is not unbreakable.
