how do i adjust the clutch on my 1983 kdx250
Posted: 03:38 am Apr 29 2016
by jasongoldberg1669
Hi everyone i have a quick question. I just bought a kdx250 and i was wondering if anyone could help me to adjust the clutch. It feels like it doesnt want to engage wheen i let the lever out
Posted: 01:07 pm Apr 29 2016
by sarrant
Not to overlook the obvious, have you played with either the in-line or lever barrel-adjusters?
Also, one reason you aren't getting any response is because this is the forum for those who are doing fork conversions for their KDX's
Re: how do i adjust the clutch on my 1983 kdx250
Posted: 01:42 pm Apr 29 2016
Yes i did plaY with both adjusters andnthat is when it became laggy
Posted: 08:00 pm Apr 29 2016
by sarrant
jasongoldberg1669 wrote:Yes i did plaY with both adjusters andnthat is when it became laggy
Then put them back where they were?
Posted: 10:35 pm Apr 29 2016
by rparrish08
sarrant wrote:jasongoldberg1669 wrote:Yes i did plaY with both adjusters andnthat is when it became laggy
Genius!
Posted: 05:02 pm May 04 2016
Okay i have put everything back the way it originally was. I changed the oil and now the damn clutch wont disengage at all. Help me please. Also if someone knows where i can get a service manual for a 1983 kdx250, i would really ne thankful.
Posted: 01:54 pm May 06 2016
by sarrant
A lot of the time, if the bike was sitting (especially with old oil) the clutch plates will swell or stick together, and just some run time will break them lose.
Otherwise, you'll have to pull off the clutch cover, and take a look at the plates.
Posted: 02:45 am May 07 2016
I took the clutch cover off and looked at the plates. They
ooked brand new. But someth7ng was making them stick when 7 pulled the clutch in. So i cleaned all them with a dry rag, just blotting whatev3r it was on them. I changed the oil again, and still have same result. I will try riding it a little in the morning and see if that helps at all.
Posted: 11:32 am May 11 2016
I did pull the cover off again to look at the plates, and it looks lie there is something causing the plates to stick together for sme reason. I think it may be from when i changed the oil, i put a small amount of lucas oil treatment in with the oil and it caused it to jelly a bit.
