1992 kdx 200 clutch, pls help me
Posted: 01:40 am Apr 11 2016
by hubbabubba_99
After installing new plates my clutch won't work I pull the cable and there is no pull back the cable just stays stuck there until I pull it back. Can someone help, pls and ty. :cry:
Posted: 01:47 am Apr 11 2016
by ss109
You installed something incorrectly. Pull it back apart and start over being methodical in how you reassemble it.
Posted: 05:56 am Apr 11 2016
by ohgood
hubbabubba_99 wrote:After installing new plates my clutch won't work I pull the cable and there is no pull back the cable just stays stuck there until I pull it back. Can someone help, pls and ty. :cry:
count the fibers and steels from the old clutch pack, then compare to the new.
SS109 wrote:You installed something incorrectly. Pull it back apart and start over being methodical in how you reassemble it.
what this guy said (just about every time) is spot on. :-)
Re: 1992 kdx 200 clutch, pls help me
Posted: 08:10 pm Apr 11 2016
by hubbabubba_99
Well I installed them all right and there is the same amount of plates on both the old and new kit so what else could it be, I also put in new springs could it be that?
Posted: 09:31 pm Apr 11 2016
by 6 Riders
Check that the activator rod is in correctly.
Posted: 02:07 pm Apr 12 2016
by david
Have you looked at a parts break down of the clutch to make sure you have all the thrust washers and judder springs in the correct places?
Posted: 08:21 pm Apr 14 2016
by hubbabubba_99
Yeah that's the exact same pic I have and yeah I did make sure with that pic but the plates don't fit like tight on my clutch basket is that a problem even though I think I installed it right. I also had a question, I seen in other dirt bikes that the rod is attached to the clutch should my activator rode be attached to any part of it?
