Drive Chain *Simple Question*
Posted: 02:39 pm Apr 09 2016
by revin9
Just throwing this out here, but I ordered a D.I.D Non O-ring chain, but should I have ordered an O-Ring chain? Thanks.
Re: Drive Chain *Simple Question*
Posted: 03:01 pm Apr 09 2016
by Corey
The thing to consider about o-ring chains is that some are slightly wider than your existing chain and that opens up the possibility of scraping against the area of your engine case where the chain revolves around the countershaft. I've had that happen before. I replaced the stock o-ring chain on my KDX with a new one and went out for a very short ride with this thought in mind and to my horror I saw some slight scrap-age at that area. Fortunately it was very minor. Primarily because of that I don't do o-ring. You don't want to weaken that area of the case.
Posted: 03:24 pm Apr 09 2016
by revin9
Will do, Ill stick with a Non-O ring!
Posted: 04:01 pm Apr 09 2016
by royadams
I use a non oring chain as well. It's seems like the slightly wider chain rubs on the side of my chain guide and wears the master link clip. I lost one clip like that then replaced it a couple times a year until it was time for a new chain. New d.i.d. chain no trouble.
Posted: 05:49 pm Apr 09 2016
by ss109
The possibility of rubbing the case is why I opt foran X-ring change. They are slightly narrower than an O-ring chain and last way longer than any non-ringed chain.
