KDX 250 1991 pinging
Posted: 02:17 pm Mar 25 2016
by impellerhead
I have a 1991 KDX 250 that when it gets really warm starts to ping/detonate when giving it full throttle from low rpms. Any ideas ?
Re: KDX 250 1991 pinging
Posted: 02:59 pm Mar 25 2016
by Julien D
what octane fuel are you running? Has the head been shaved or anything? Been through the jetting process?
Posted: 03:35 am Mar 27 2016
by impellerhead
Not shaved head, larger jetting than original. Highest octane we have on the gas station in Sweden.
Posted: 09:51 am Mar 27 2016
by Julien D
Check for air leaks. Check also that the timing has not been too far advanced.
Posted: 12:06 pm Mar 27 2016
by Jaguar
pull the needle up one or two notches to enrichen the mixture,
retard the ignition
Posted: 05:27 am Mar 28 2016
by impellerhead
I have pulled the needle up and retarded the ignition, No air leaks. I'm starting to think either the ignition is not working as it should when it gets warm or the KIPS not working as it should.
Posted: 08:13 pm Mar 30 2016
by david
Are you sure it isn't overheating
Posted: 05:56 pm Apr 02 2016
by impellerhead
That was my very first thought so I took apart the water pump to see if there was something wrong there but no.. So i don't think it is overheating.
Posted: 02:12 pm Apr 13 2016
by impellerhead
I hope I am on to something now because I read newer Kawasaki 250:s act precisely like mine do if the pickup coil has to small air gap.
Those bikes has a external sensor though, This is what it looks like on the KDX 250 1991. Would be nice to have a service manual to see
what gap it should have.
