Waterpump shaft with a broken gear
eprovenzano
Post by eprovenzano »
On my 91 basket case I have a noise in the bottom end. The crank rolled smoothly, and knowing the previous owner recently put new clutch plates in I was thinking something was amiss with the idler gear. So I pulled the clutch side cover and found the kickstart return spring was not in its little hole, it was rubbing on the clutch gear... hence the noise I could here...
I reinstalled everything to only to now hear a clunking noise... So I pull it apart again and find a broken tooth on the water pump shaft
This happens when you try to force the side case on without getting the gears to mesh properly... (ask me how I know, as I learned that valuable expensive lesson before). No this one came to me this way...
I looked up part number for the shaft, 13234-1092. The only shaft I've found (so far) is for a H series KDX part number 13234-1091... Does anyone know if they are the same, or did Kawi change the design a little in the H series KDX... Better yet, does anyone have a spare water pump shaft they'd be willing to part with. :please:
1991 KDX basket case... being rebuilt
2001 KTM EXC 380... two stroke heaven
2000 KTM EXC 300, son's
1993 Kawaski Bayou 400 4x4
2008 Yamaha Vstar 1100 Silverado
eprovenzano
Re: Waterpump shaft with a broken gear
I did some digging and compared pictures. I found they are different. From my research, there's a difference the following years, 89-90, 91-94, and 95+ Damn.... :sad: I'm struggling to find one for my 91.
eprovenzano
I'm thinking I "may" be able to have the H series machined to match the E series shaft.
Here are pics of both the H and E series shafts. As you can see the shaft of the H series that connects to the impeller is larger than the E series, also the connection of the impeller to the shaft is different... The part of the shaft that would lie in the bearing to me look very similar. As long as the H series shafts are longer and or wider, I'm good... Are the gears the same?
Pic of an H series water pump shaft
Pic of an E series water pump shaft
Davenay67
Post by Davenay67 »
This might be a long shot, but did you try motorcycle salvage yards. I know there are a number of resources online now for sourcing used parts for motorcycles.
Not a comprehensive list by any mean, but a bit of a start....
http://www.uneedapart.com/used-motorcycle-parts/
http://www.usedmotorcyclesandparts.com/
http://www.cannibalcycle.com/
I used to spend many a happy hour scrounging through my local salvage yards looking for cheap parts to keep my beaters going. That type of operation seems long gone now, but the reach of the internet has broadened the capacity to find parts.
Davenay67
Post by Davenay67 »
david
Country: UNITED STATES
Post by david »
How about just the gear. Found this on ebay
http://www.ebay.com/itm/1991-KAWASAKI-K ... yP&vxp=mtr
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
eprovenzano
david wrote:How about just the gear. Found this on ebay
The gear is what goes onto the crankshaft. I need the opposing shaft that turns the impeller... Thanks though...
The part number I need is 13234 1092
Davenay67
Post by Davenay67 »
Looks like Ron Ayers has them in stock....
http://www.ronayers.com/oemparts/p/kawa ... -comp-pump
eprovenzano
Davenay67 wrote:Looks like Ron Ayers has them in stock....
I looked at their site earlier and while it shows it available, I "ASSUMED" it was not... I just placed an order so we see if it available... :mrgreen:
Thanks
david
Post by david »
Service Honda's site shows the shaft as 'no longer available'.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
eprovenzano
david wrote:Service Honda's site shows the shaft as 'no longer available'.
Most of the sites I've looked at show the item is no longer available... But I keep trying...
Has thanked: 5 times
Been thanked: 11 times
I have wondered in the past. I THINK it may be possible to use the H series shaft if you also use the H series impeller. You may also need H series seals / bearings. Hard to say for sure as I dont know of anyone who actually tried.
david
Post by david »
Well the H uses a typical carbon/ceramic water pump seal, where the E uses a conventional rubber lip seal(s). I would think the seal locations are different sizes and not interchangeable.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
eprovenzano
I agree, but I'm thinking as a last resort, can have an "H" shaft machined down to match an "E" series. For a machinist with a good lath it shouldn't be too difficult. Of course this is the shafts are at least the same diameter (if not bigger), the length can be made to work, and of course the gear has to be the the same.
david
Post by david »
Surly you should be able to find someone on here that has one. The other thing you can do is find a seller on eBay with some other parts for the same year your looking at, and message them to ask if they have the water pump shaft.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
eprovenzano
I put out quite a few emails looking for the shaft. The salvage yards I called don't have any
david
Post by david »
Sounds like your on it. Good luck, wish I had one for you.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
eprovenzano
Taking the advice from the forum, I went through the part listing for 91 - 94 KDX's on ebay and asked those selling parts if they have a water pump shaft. I sent off quite a lot of emails, so hopefully someone, somewhere has to have one available.
Edit: I've already received a few responses... sorry no we don't have one...
As I look at the pics of the H series and E series pump, I believe I can have the H series machined to match the E series... but I'll hold off on going down that path until we have no other choice.
eprovenzano
The majority of the vendors I've contacted have responded and state they do not have the water pump shaft I need, most state they've sold them. So just in case I need it, I purchased an H series water pump shaft for $10... If the gear is the same, as a last resort I'll have it machined to match the E series shaft.
eprovenzano
So far no luck... So I'm staring to look at plan "B". I did find the water pump bearing, and the water pump drive gear on the end of the crankshaft are the same between the E and H series. So this leads me to believe the gear is the same... Now If the shafts (as I hope) on the H series are at least the same if not longer, and are the same diameter or bigger... We can make this work.
