chinese footpegs
canamfan
chinese footpegs
Has anyone tried the Chinese knockoff footpegs? The price is good but having a footpeg snap off could be painfull.
Bitteeinit
Re: chinese footpegs
Yep, need to be ground down a bit to fit, but they're very nice. Much wider and more stable than stock imo. I've got size 13 feet, so I found them better.
Sent from my ASUS_Z00AD using Tapatalk
david
- Country: UNITED STATES
X2. Haven't been able to ride them yet, but they seem pretty strong.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
bultaco4ever
canamfan
chinese footpegs
Yes there are two designs I see, one looks like it has a cast solid lug for the pivot, the other has what appears to be two pieces of steel welded on with a hole drilled through for the pivot. I thought the cast version looked stronger. Thanks for the replies.
pumpguy
- Been thanked: 2 times
chinese footpegs
I have a pair of the cast ones. Seem strong enough but had trouble fitting return springs. Ended up doing a little machining around where the spring fits into the hole in the peg.
Then found a pair of aluminum pegs from a Yamaha I think for $5. Peg itself is about same size. May need to do some machining to get them to fit. Haven't done that yet.
david
chinese footpegs
I had no problem fitting the springs, but you do have to swap springs from the left side to the right.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
canamfan
chinese footpegs
I ordered a pair, will see how it goes. Thanks again for all the response. Now if I could motivate myself to work on my hybrid.
