Are KDX250 Triples A Direct Bolt On For E Model KDX200s?
Posted: 07:18 am Nov 24 2015
by KDXFZRRD
Trying to figure out if 91-94 KDX250 triple clamps are a direct bolt on to the 89-84 E model KDX200s. Anyone know for sure? Thanks.
Posted: 03:32 pm Nov 24 2015
by sarrant
It looks like they should bolt-on.
Posted: 07:34 pm Nov 24 2015
by 6 Riders
KDXFZRRD wrote:Trying to figure out if 91-94 KDX250 triple clamps are a direct bolt on to the 89-84 E model KDX200s. Anyone know for sure? Thanks.
Well, the 93-94 KDX 200 used the same front end and ALL KDX 200/220s use the same stem. If you are looking at buying a set from a KDX250, they need to be reasonably priced as they (IMO) are not a better fork than an H series fork.
Posted: 07:48 pm Nov 24 2015
by KDXFZRRD
My plan is to use 91-94 KX125 forks in the KDX250 triples. After some research it looks like this will be a bolt on set up if I use the kx wheel.
Re: Are KDX250 Triples A Direct Bolt On For E Model KDX200s?
Posted: 08:10 pm Nov 24 2015
by sarrant
If you are using 91 KX125 forks, they will bolt directly up in their own triples.
Posted: 09:29 pm Nov 24 2015
by KDXFZRRD
I did not know that. Thanks for the info. That saves me some $$!
