2014 HUSQVARNA TXC310r issue
Posted: 09:10 pm May 29 2015
Hi,
I just recently bought a 2014 husqvarna txc310r from a pro enduro racer I know. When i got it it ran great and had around 30 hours on it, but after about 2 hours it sheared a flywheel key. I replaced the key and tighted the flywheel to spec and removed the aftermarket ECU because i thought it may be advancing the timing. Then it sheared another..and another....and another...and another . I tried removing the starter motor, using red loctite, over tightening the nut, but nothing has worked. I have no idea whats going on, if any of you guys have any ideas id really really appreciate it. Thanks!
