Does this kx 250 cylinder look usable?
Posted: 05:28 pm Apr 14 2015
by Actionman
My 2000 kx 250 cylinder had a sizable chunk missing from one of the transfer port bridges. I used a small file and 2000 grit sandpaper to blend the chunk out, but now that particular bridge looks thin. Ive attached pics of both side's transfer ports as a comparison.
Untouched side:
Posted: 05:29 pm Apr 14 2015
by Actionman
Damaged side:
Re: Does this kx 250 cylinder look usable?
Posted: 06:15 pm Apr 14 2015
by s10gto
As long as the locator pins don't sit the rings there I don't think it will be a issue. Cylinder looks sleeved anyways.
Make sure you clean up the burr in that right port in the top pic.
Posted: 06:41 pm Apr 14 2015
by Actionman
Its a sleeve. Ive sanded out the burrs around that port also. Ill probably use the cylinder until I get a non-sleeved ebay cylinder and get it replated.
Posted: 07:10 pm Apr 14 2015
by doctord23
I have one from a '99 at home that I'd be willing to sell.
Let me look it over tonight and see what condition it is in and what the bore is.
I'll pm you some pictures later.
Posted: 07:16 pm Apr 14 2015
by Actionman
doctord23 wrote:I have one from a '99 at home that I'd be willing to sell.
I got laid off from my job last week, so I may end up HAVING to use this cylinder, which is why im worried :) send pics anyway though.
Posted: 10:36 am Apr 16 2015
by Julien D
It'll run.
Posted: 10:38 am Apr 16 2015
by KDXohio
hit it with some acid and scotch brite itll be ok
Posted: 12:02 am Apr 19 2015
by Actionman
I put a ring through it and checked end gap and it looked like it still has a good seal. I chamfered the high spots around the ports and it looks good. Thanks!
