CLutch install problem
cuervo
Post by cuervo »
Hi , ¿this cabla position is the correct?, I believe that lever comp must be move a little forward. :snooty:
s10gto
Post by s10gto »
I checked my H series and looks about right. That spring looks unhooked/bent.
cuervo
Re: CLutch install problem
Post by cuervo »
Hi s10gto , how is the spring right position? , it is my first bike , i'm a roockie :oops: xd.
Tedh98
Been thanked: 2 times
Post by Tedh98 »
Looks close to mine as well. But if you use 0 or 1 washer under the pusher rod could account for differences.
The big question is - is the clutch operating correctly?
s10gto
Post by s10gto »
When the spring is correct one end hooks the case. The other hooks to the lever. Here's a pic. :grin:
