What other rear wheels fit 96-06 KDX 200?
motoracerx
Post by motoracerx »
Head hurts from searching.....what other wheels are a direct fit for 96-06 kdx 200?
I know if it's a later model rear wheel, it will be 19"...is that a bad thing?
KDX_Johnny
Post by KDX_Johnny »
Same Oem part number (41034-1216) on the bikes listed:
Oh and just as a reference it's 95-06. Good Luck!
1991 KDX250-D1 KDX250 REAR HUB
1992 KDX250-D2 KDX250 REAR HUB
1993 KDX250-D3 KDX250 REAR HUB
1993 KLX650-A1 KLX650R REAR HUB
1994 KDX250-D4 KDX250 REAR HUB
1994 KLX250-D2 KLX250R REAR HUB
1994 KLX650-A2 KLX650R REAR HUB
1995 KDX200-H1 KDX200 REAR HUB
1995 KLX250-D3 KLX250R REAR HUB
1995 KLX650-A3 KLX650R REAR HUB
1996 KDX200-H2 KDX200 REAR HUB
1996 KLX250-D4 KLX250R REAR HUB
1996 KLX650-D1 KLX650R REAR HUB
1997 KDX200-H3 KDX200 REAR HUB
1997 KDX220-A4 KDX220R REAR HUB
1997 KLX300-A2 KLX300R REAR HUB
1998 KDX200-H4 KDX200 REAR HUB
1998 KDX220-A5 KDX220R REAR HUB
1998 KLX300-A3 KLX300R REAR HUB
1999 KDX200-H5 KDX200 REAR HUB
1999 KDX220-A6 KDX220R REAR HUB
1999 KLX300-A4 KLX300R REAR HUB
2000 KDX200-H6 KDX200 REAR HUB
2000 KDX220-A7 KDX220R REAR HUB
2000 KLX300-A5 KLX300R REAR HUB
2001 KDX200-H7 KDX200 REAR HUB
2001 KDX220-A8 KDX220R REAR HUB
2001 KLX300-A6 KLX300R REAR HUB
2002 KDX200-H8 KDX200 REAR HUB
2002 KDX220-A9 KDX220R REAR HUB
2002 KLX300-A7 KLX300R REAR HUB
2003 KDX200-H9 KDX200 REAR HUB
2003 KDX220-A10 KDX220R REAR HUB
2003 KLX300-A8 KLX300R REAR HUB
2004 KDX200-H10 KDX200 REAR HUB
2004 KDX220-A11 KDX220R REAR HUB
2004 KLX300-A9 KLX300R REAR HUB
2005 KDX200-H11 KDX200 REAR HUB
2005 KDX220-A12 KDX220R REAR HUB
2005 KLX300-A10 KLX300R REAR HUB
2006 KDX200H6F KDX200 REAR HUB
2006 KLX250H6F KLX250S REAR HUB
2006 KLX300A6F KLX300R REAR HUB
2007 KLX250H7F KLX250S REAR HUB
2007 KLX300A7F KLX300R REAR HUB
Just a square trying to ram myself into that circular hole...
6 Riders
Re: What other rear wheels fit 96-06 KDX 200?
Post by 6 Riders »
Just a little note here; My rear wheel from my 93 KDX swap onto my 95. So you could add those wheels to the list.
diymirage
Post by diymirage »
motoracerx wrote: I know if it's a later model rear wheel, it will be 19"...is that a bad thing?
depends on your riding style
there is a reason MXers run 19 inchers but the 18 inch tires will have better sidewall flex and less chances of pinching a tube
newbbewb
Post by newbbewb »
for a fact, my kdx250 parts bike rear hub was different than my kdx200 hub. I can't remember the difference for the life of me. That doesn't mean the rear assembly won't fit though.
And to help out the OP, personally I have no problem with the 19" rear wheel on the hybrid, but the good trail worthy tire selection kind of blows. Supposedly 19" are more prone to pinch flats, I haven't had that problem in the summertime and I didn't baby it by any means at 12 psi. For the time being, 19" rear wheels can get an at81RC, RC denoting the double sidewall thickness, but double side wall weight as well. Good tire BTW!
93 kdx200-Highly modified
89 kx125/kdx200E engine
Buelldustin@gmail.com
Many of the KX wheels will fit right on also. I have a 2000 KX 250 rear wheel that fits. The later KX wheels when to a larger rotor so they are not going to work. You could search the rotor part number for the KX to get a better idea of the years.
