kips lubrication
dualscotty
kips lubrication
Hi there.what lubricates the kips system the premix oil or the gearbox oil.I'm sure its the premix oil.just want to be sure.thanx
- JoKDX220r
dualscotty
dualscotty
- Tedh98
Re: kips lubrication
Does the noise change when you pull in the clutch? If so, then probably just the normal noisey KIPS.
dualscotty
Pulling on the clutch doesn't make it go away. Changes the pitch a little.rev the bike up and it goes away.
dualscotty
- Tedh98
It is noisey. Running a full quart of tranny fluid seems to quiet it down a little.
dualscotty
If the premix lubricates the kips .how does the bottem end oil lubricate the kips.premix lubricate top part of kips and bottem end oil lubricate lower end of kips....thanks .
- Has thanked: 10 times
- Been thanked: 12 times
Correct. Premix lubes the upper parts located in the cylinder. The KIPS governor and drive gear, located inside the right side engine cover, are lubed by the transmission oil.dualscotty wrote:If the premix lubricates the kips .how does the bottem end oil lubricate the kips.premix lubricate top part of kips and bottem end oil lubricate lower end of kips....thanks .
dualscotty
Thank you.is the noise mainly from the upper or lower part of the kips or combination of both.thanks..I know I'm asking a lot of questions..I had surgery a month ago and I have another month of recovery here at home(boring!).so I have time on my hands.
dualscotty
- Tedh98
Does that have friction modifiers in it?dualscotty wrote:I have 10w40 synthetic in the gear box.
I have been using ATF for years and like the price and how the clutch and transmission function.
dualscotty
Its valvoline synthetic like you would use in your car.is the atf you use the same as you would use in your cars automatic tranny
- Tedh98
dualscotty
