Wiring assistance- Australian spec
Posted: 07:37 pm May 28 2014
Hi all,
It's my first post here so I'd firstly like to say thanks to all the great people here who have provided me with some very good information.
I've got a 97 KDX200 Australian spec which I'm part way through restoring. I have a question about wiring, which I realise is likely to be different than most of the bikes on here but here goes;
I have 5 wires coming from the magneto- 2 pick up wires (running to CDI) and 3 yellow running to the regulator so far so good.
From regulator I have 3 wires- 1 common ground and 2 white wires (1 is slightly thicker than the other)- here's where it gets interesting
If I connect the thicker white wire to the key mechanism which provides power to the coil- I get spark, the bike sounds like it wants to run but just cuts out after I stop kicking.
If I connect both white wires going through the key and back to the CDI the bike will run fine. No white wires connected and I get no spark.
Anyone have any idea what the difference between the two white wires is? I was thinking one would be power to ignition and 1 would be power to lights but that doesn't seem to be the case.
Cheers
Cheers
