Thoughts?
Posted: 01:16 am May 15 2014
by Brom32
Is this a good buy? How much do you think fork seals will cost me? http://pages.ebay.com/motors/link/?nav= ... 37&alt=web
Re: Thoughts?
Posted: 05:33 am May 15 2014
by Tedh98
Race Tech or SDI will have prices on those. Best to replace the bushings as well.
But i would tear them all the way down and inspect first. No point in replacing seals if other wear items need to be replaced in order for them to be safe and perform correctly.
I would also contact the seller to make sure all the threads on the lugs are in good condition.
Re: Thoughts?
Posted: 02:24 pm May 15 2014
Those are 1993 at the newest. That is too much to pay for those.
Thoughts?
Posted: 07:01 pm May 15 2014
by RyanKeyte
Those are not 98 forks. Those are older. 43 mm forks are fine, i ran some on my KDX for a bit, but I could not find anyone that made a spring with a heavy enough rate for me. ( Im 210- no gear). If you are a light guy, and like light springs, they can work. The newer 500s have a 46 mm fork. IIRC race tech makes springs up to a .48 or .50 kg (thats what i have now in 2001 kx500 forks). --Get an ENTIRE 500 set up, direct swap ... :-)
Re: Thoughts?
Posted: 09:45 pm May 16 2014
by Brom32
I am going to do the full swap. Is there a good place to buy the kx500 forks other than eBay?
Sent from my XT907 using Tapatalk
Thoughts?
Posted: 07:04 pm Dec 07 2014
by motoracerx
RyanKeyte wrote:Those are not 98 forks. Those are older. 43 mm forks are fine, i ran some on my KDX for a bit, but I could not find anyone that made a spring with a heavy enough rate for me. ( Im 210- no gear). If you are a light guy, and like light springs, they can work. The newer 500s have a 46 mm fork. IIRC race tech makes springs up to a .48 or .50 kg (thats what i have now in 2001 kx500 forks). --Get an ENTIRE 500 set up, direct swap ... :-)
Bump...with a question.
Do stems need to be swapped out, or are the the KX 500 triples and forks a direct bolt on with no mods?
Thoughts?
Posted: 07:27 pm Dec 07 2014
by 6 Riders
It's direct bolt on!
Re: Thoughts?
Posted: 04:40 am Dec 08 2014
by motoracerx
Thanks, I've read sooooo much on here about the conversions and just when you think you got it figured out, you read something else that confuses you.
I bought a set of '99 KX 250 forks, triples, axle/spacers, brake caliper w/MC and line, a set of fatbars with 1 pc. handlebar mount .
My thoughts were to use 97-04 kx 500 triples to avoid a stem swap with the KDX and kx 250, but they are non existent thus far.
I read about the different offset with the 500 trips vs 250 trips, doesn't seemed to be something I should worry about with my novice riding status.
What about KLX 300 triples with the KX 250 forks, is that an option? Trying to find info on that.
I would be sending parts to RB to have the stem swap and axle work done for the KX 250 conversion, but if I could do a swap without sending parts out, I'd rather do that.
