Page 1 of 2
starting my hybrid
Posted: 08:42 pm Mar 16 2014
by volkoff
Re: starting my hybrid
Posted: 08:56 pm Mar 16 2014
by Tedh98
You definitely use the inner seals. They just go in the same location after the swing arm is cut. You will see that there is still plenty of room there for those seals after you make the cuts. It would be best to measure your specific application for the amount to remove from the swing arm. It will likely be close to 9mm on each side, but since you can't add aluminum back, you should measure.
With all that being said, the amount you remove from the swing arm isn't as critical as what you remove from the swing arm bushings.
Nice score on getting the kx for $600
Posted: 09:49 am Mar 17 2014
by bufftester
Tedh98 wrote:You definitely use the inner seals. They just go in the same location after the swing arm is cut. You will see that there is still plenty of room there for those seals after you make the cuts. It would be best to measure your specific application for the amount to remove from the swing arm. It will likely be close to 9mm on each side, but since you can't add aluminum back, you should measure.
Good advice. Or as the old rule goes "measure twice, cut once". You can get most any machine shop to drill the case for you. Just make sure that you mock up your entire intake/engine/exhaust before you weld any engine mounts. Much easier to sort out the fitting of the pipe, exhaust mounts, carb and airbox before hand.
Posted: 11:13 am Mar 17 2014
by volkoff
I am quite capable of doing the drilling, I am just weighing out the price of all the bits vs just having someone do it. I believe there is someone on here that has the bits to loan out. I imagine going slow, lots of oil and no distractions and it should be pretty easy. I am going to be using a PC Platinum pipe that came with the bike. I have nothing to compare to it so I am going to use it.
Posted: 10:17 am Mar 18 2014
by bufftester
Skippy used to pimp out the drill bits
community reamer topic, he'd be the one to contact to see if they are still available. I bought the bits and they were pricey, I think I spent around $100 on the 3 bits and reamer. Lots of cutting oil and slow worked fine. You actually are only taking material off on about 15 mm on each side of the case, the center portion is hollow. I bought the bits initially because my local machine shop didn't have the metric reamer. I have sinced loaned it out and it never came back
Posted: 10:53 am Mar 18 2014
by Tedh98
bufftester wrote:I bought the bits initially because my local machine shop didn't have the metric reamer.
Same here. The machine shop ordered (and I purchased) the 17mm reamer. I still have it in the workshop. I think it cost me $40.
Posted: 08:53 pm Mar 19 2014
by volkoff
Well the motor is on the bench and the swingarm bearings are out. I do not know if you can call them bearings though. They were just rusty pieces of metal, just fell apart. also found this little issue where the chain rubbed through. I think I am going to fill with weld and grind smooth. I will probably sand blast and powder coat it silver.
[img]
[/img][img]
[/img]
Posted: 06:45 pm Mar 26 2014
by volkoff
Posted: 07:09 pm May 04 2014
by volkoff
Well, a little update. I am sending the cylinder out tomorrow to Millennium for a replate. I also sent them a new Weisco piston/rings. Motor is machined to accept the KX 17mm shaft. I am waiting on my brother in law to weld the nasty gouge in the swingarm. I was able to purchase an IMS 3.1 gal natural color tank. I have all my new swingarm and linkage bearings. I am planning on cutting the motor mounts off this week. Once I mock up the new motor mounts I will model up some nice ones with the Kawasaki "K" laser cut into them. I think this will add a little touch of cool to the build. I am hoping the KX air box and boot fits. I have access to a 3D printer at work, so I will be able to model whatever size and shape adaptor I need to make it fit and print it. I hope the pipe does not give me too much of a headache.
Posted: 07:05 pm May 06 2014
by bufftester
The KX airbox and boot will work, but you will need an adapter to match the larger diameter KX boot to the smaller diameter KDX carb. I used the lip from the KDX boot as an adapter (my build thread has pics) As for the pipe, mock up the pipe, airbox and motor mounts before welding anything. proper placement of the motor to allow airbox fitment and pipe fitment will determine motor mount dimensions.
Posted: 10:07 am Nov 28 2014
by volkoff
starting my hybrid
Posted: 10:12 am Nov 28 2014
by Tedh98
Those are awesome mounts and brackets!
Posted: 10:34 am Nov 28 2014
by volkoff
thanks Ted. I could not just hand cut some tabs when I can model whatever I need and have it printed then laser cut. I need to tweak a little on the brackets, but I think I am good to go. I am hoping to have final welding done next week. I will be having the frame sand blasted then powder coated texture black. $10 for a frame at work.
Posted: 06:31 pm Dec 26 2014
by volkoff
starting my hybrid
Posted: 09:10 am Feb 08 2015
by volkoff
starting my hybrid
Posted: 08:09 pm Feb 08 2015
by GI_JO_NATHAN
Very cool!
Posted: 01:24 am Feb 09 2015
by Tioli
Wow you make it look and sound so easy.
starting my hybrid
Posted: 01:33 pm Mar 08 2015
by volkoff
Finally finished. Started after a couple good kicks and just purrrrrs. there is a good stumble off idle but it is pretty cold here and also motor is all new and fresh. I am not going to mess with carb till we have warm weather.
Posted: 11:20 pm Mar 08 2015
by chkdx
Nice bike! I like the sidestand, what brand is it?
Posted: 12:55 am Mar 09 2015
Wow! Great job! Your work has paid off for you. Nice bike.
chkdx:
http://www.promotobillet.com/p-18131-kickstands.html
I think.
