Plasti Dip
Posted: 06:45 am Dec 25 2013
by screwloose
Hey Guys,
I found this tip in the forums somewhere and though I would give it a go as its impossible to find boots for my 87 KDX.
Bought a can for $30 from autobarn and had some great results.
The cracks that were once showing are now completely covered and the stuff is pretty strong and flexible once set.
I gave it 4 coats and had plenty left over.
The only thing I would had done differently is cover the holes for the screws before spraying.
One of bolts got snagged going in, but it did show off how flexible and strong the stuff is :)
Re: Plasti Dip
Posted: 10:34 am Dec 25 2013
by adam728
The real test will be how it holds up to fuel. The evaporating hydrocarbons may migrate through the cracks and eat right through the plasti dip. Or it may be very fuel resistant, I've never looked into it.
Sent via morse code
Re: Plasti Dip
Posted: 02:19 pm Dec 25 2013
by Goofaroo
I used this on the boots when I rebuilt my 87 model and it has held up perfectly for over a year. However, mine only had surface cracks and nothing that went all the way through so I can't say how well it would hold up to fuel.
Plasti Dip
Posted: 11:02 pm Dec 26 2013
by ss109
Small tip when working with Plasti-Dip, as soon as you finish spraying your final coat, remove any masking immediately. Waiting until it dries will cause you to pull up the edges, and make things much harder, when removing it which you don't want
Re: Plasti Dip
Posted: 11:58 pm Dec 26 2013
by hbgod
plastidip is amazing stuff but $30????? its like $10 at lowes.
Plasti Dip
Posted: 10:54 am Dec 27 2013
by dfeckel
I did this same trick with my '87. I probably have 20 hours ride time with no problems whatsoever. My airbox boot did have through-and-through cracking, and the Plasti Dip has worked great.
Re: Plasti Dip
Posted: 08:33 pm Dec 27 2013
Hmm! Thanks for the reports.
Re: Plasti Dip
Posted: 06:53 pm Jan 07 2014
by screwloose
hbgod wrote:plastidip is amazing stuff but $30????? its like $10 at lowes.
Perks of living in aus ;)
