Air filter test
- adam728
Re: Air filter test
Nice write up!
Was your UNI filter just a single layer? From the pics it just looks like the outer coarse layer of the two-filter system. I've ran Uni filters on my YZ for about 6 years with no noticable dirt past it. Inner foam seemed the same the stock filtet and No-toil filters I also had.
Sent via morse code
Sent via morse code
- Tedh98
- Been thanked: 2 times
Re: Air filter test
Thanks.
The UNI was a 2 piece.
If anyone wants it, they can have it for just shipping. Only 2 rides on it and 3 tests.
- Tedh98
Re: Air filter test
adam728 wrote:I've ran Uni filters on my YZ for about 6 years with no noticable dirt past it. Inner foam seemed the same the stock filtet and No-toil filters I also had.
I read a lot of posts from people swearing by UNI and Twin Air. When I was seeing the dirt passing through, I questioned my oiling technique. But after watching several videos of pro's mechanics oiling filters and one done by UNI, I realized I definitely wasn't under-oiling my filters.
The light test was quite telling. If light was shining directly through, then that represents a straight shot for a piece of dust/dirt. Not very likely that a particle of dirt would go straight through, but when you have tens of thousands of fine dust particles swirling around in a bucket, I guess some will find that straight path.
Out of curiosity, does your YZ use that rubber grommet where the bolt passes through?
- 6 Riders
Re: Air filter test
Great job! :great:
I wold love to see you test the No-Toil filters, both the "quick filter" and the premium one.
- adam728
Re: Air filter test
No rubber grommet on the yz, just a big cupped washer that compresses the foam to a shoulder on the plastic cage.
To be fair, twin airs are my preference. The slightly smaller size makes getting the filter in and out much easier, without scraping half the dirt into the box.
Sent via morse code
Sent via morse code
- Has thanked: 173 times
- Been thanked: 43 times
Re: Air filter test
WOW! Thank you for your excellent write up!
It is quite interesting!
- diymirage
Re: Air filter test
im starting to fear you have too much time on your hands my friend...should have gone riding
- Tedh98
Re: Air filter test
diymirage wrote:im starting to fear you have too much time on your hands my friend...should have gone riding
Tell me about it!
But in this case I had to find out where the dirt was coming from before I did any more damage to the engine.
- Tedh98
- adam728
Re: Air filter test
PM me an address and I'll send you a no toil for a YZ250. It is a different shape buts looks like it will fit the kdx cage well enough to seal.
Funny. My sand fill kdx purchase has a uni filter. Stone dry, and inner layer is not installed all the way down on the cage.
Sent via morse code
Sent via morse code
- adam728
Re: Air filter test
Whoops. Apparently I am not "authorised" to send or read private messages. Let's try again at amcgilto@gmail.com .
And yes, authorized is misspelled in the notification.
Sent via morse code
Sent via morse code
elusive
- Tedh98
Air filter test
Thanks to Adam728 for sending me the NoToil. I've added my results to the bottom of the page: Update - My air filter test
While on the topic of NoToil, for those that have used the original and the Evolution, does the Evolution do a better job of staying in the filter and not settling out over time?
