Floating Ground
- TheJackRabbit
Floating Ground
would i still need to float the ground to convert to DC if only the rectifier is connected to the frame? or would that cause problems with the ignition coil that is grounded under the tank?
I'm smarter than I act
- adam728
Re: Floating Ground
Need to float due to ignition, yes. Been there, done that, then fixed it.
Sent via morse code
Sent via morse code
